Please Help Asap
Old Jul 22, 2003 | 02:41 PM
Green G0blin's Avatar
Please Help Asap
http://csce.uark.edu/~jgbertr/rb/opti_vacuum_conn.jpg
on that pic there...there is pcv valve (to intake manifold port under throttle body)
well my car is hesitating and stumbling. and i noticed i had no pipe here...where does it lead to? and would this cause my problems?
Old Jul 22, 2003 | 02:46 PM
Chris 96 WS6's Avatar
The PCV tube connects back into the intake manifold at the front...underneath the throttle body.
Old Jul 22, 2003 | 02:50 PM
yeah. i finally figuered it out..but would that cause my hesitation/stumbling? and cause the car to turn off?
Old Jul 22, 2003 | 05:19 PM
Carlos01SS's Avatar
How many miles do you have on your car?
What mods have you done to:
The engine?
The exhaust?
Any changes to any valves?
Are the IAC/EGR valves factory, or have you replaced them recently?
How many miles do your plugs/wires/coil/cat/fuel filter/Opti/waterpump/O2 sensors have?
Have you had it scoped yet?
Old Jul 23, 2003 | 08:39 AM
miles: 75,000
year: 1996
mods: lt4 hot cam, ported/polished lt1 heads, stall, gears,
suspension, jet hot long tube headers, true duals.
engine: 5.7 lt1
exhaust: long tube headers, x pipe, true duals
no changes to the valves.
IAC factory, egr removed.
about 30 miles on: plugs, wires, 02 sensors, fuel filter
oringial opti, coil and water pump.
and no cats.
Old Jul 23, 2003 | 05:56 PM
Unhappy
TTT
Old Jul 23, 2003 | 06:44 PM
Carlos01SS's Avatar
miles: 75,000
year: 1996
engine: 5.7 lt1
and no cats.
It could be a couple of things, maybe getting it dyno-tuned, that may help with the hesitation, getting the fuel/air mixture would be a great thing to dial in. Also, have you ever cleaned out the TB/IAC valve assembly? That would probably help, it CERTAINLY wouldn't hurt.
Changing the plugs/wires once a year wouldn't hurt either
Now was that 30 miles or 30K miles?
It MIGHT be the Opti going out on you.
Have you scanned for codes?
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
