Plugs........is it really that hard????
Old Jul 22, 2003 | 08:02 AM
S.J.S.'s Avatar
Sup all......... I'm gonna do a tune up on my 97 ZA4 and all I've heard is that its a bitch to change the plugs. How hard is it and what problems will I have? And while I'm at it, what else should I change?
Thanks guys SJS
97Z A4, K&N cold air, March Pulleys, MAF, air foil, Eibach Pro Kit, TB bypass, 160 stat, Flow master Catbacks.
Old Jul 22, 2003 | 08:06 AM
Green G0blin's Avatar
i just switched my plugs last night.
took about 30 mins to do the driver side.
2-3 hours to do the passenger.
it took me like 30 mins to do the first 2, and damn the last 2 are really hard.
i have several cuts and scratchs on my arms sucks, not only that...seems the car still runs like crap. so i did that for nothing!
Old Jul 22, 2003 | 08:10 AM
LWillmann's Avatar
I have Muscular Dystrophy, and a pacemaker and I did most of mine on my own.
My arms don't straighten out all the way so I have to go at things a little differently than most people, but I managed to get the front three plugs on the driver's side from the top, and the back one from the bottom.
The wires gave me more trouble than anything because I worked the Taylors into the stock looms.
The passenger side, I got the middle two from the top.
Then someone else came over to help and he did the last two. I think he did the back passenger plug from the bottom with the starter moved.
I did the wire routing on the passenger side and it was a pain as well, because of the power steering pump. But if you take your time, you'll get it.
Old Jul 22, 2003 | 08:52 AM
94formulabz's Avatar
yes it is a major pain in the **** the first time. The wires suck too. There are plenty of good writeups though if you search for it. Dealer charges for this are outrageous so you can save yourself some buck if you have the time and patience.
Old Jul 22, 2003 | 09:25 AM
HardcoreRM125's Avatar
Double check after you do them that the wries are on the rite place on the Opti, i donno how many ppl have posted on this board that jsut did plugs n wires and cant figure out why their car is running like *** and all because they didnt plug em into the opti rite lol
Old Jul 22, 2003 | 09:45 AM
CANTONRACER's Avatar
My MSD wires came with little white plastic pieces that have the spark plug number on them. It makes it much easier this way.
My spark plugs take about 1/2 hour to replace them all now. But, the reason for shorter amount of time, BMR k-member, Hooker LT's, no AC, and no air pump. It is actually getting easier to work on my car, or I might just be getting better at it.
Old Jul 22, 2003 | 09:59 AM
bad95z28's Avatar
thats exactly how I feel
Old Jul 22, 2003 | 10:07 AM
revtime's Avatar
It does get easier the more you work on the car.
Funny thing is, most cars you mod em up and they get harder to work on. 4th gens if you pick the right aftermarket parts it actually gets easier to work on. Take out useless crap like AC and AIR and you really get some room. Dare I say it is almost enjoyable to work on my car now.
FYI, the very first time I did plugs on my Z it took me 2 days.
Old Jul 22, 2003 | 10:17 AM
scoobysnax83's Avatar
The worst part is when you're in an auto hobby shop and everyone's wondering why it takes you 2-3 hours to do plugs. I just want to slap them and ask if they want to do it. PITA, but definitely worth it. Its all about maintenance.
Old Jul 22, 2003 | 10:22 AM
Kuma's Avatar
Well if you ever tried to change an alternator on an early Saturn, our plugs seem like a gift sent from heaven...or at least something the devil himself spent only 6.5 hours designing.
Old Jul 22, 2003 | 11:04 AM
Worst car to work on is a Cutlass Supreme with the 3.4 in it... Theyre incredibly cramped, nearly impossible to get to anything at under the hood with out a **** load of work ... and to top it off they about as reliable as a Yugo ... My friend has one and a few tiems **** would go bad on it that we had to try and fix ... its a nightmare , or at least to me it seems far worse then my LT1 ...
Old Jul 22, 2003 | 11:23 AM
N2OpwrdTA's Avatar
Its not impossible, or even hard after you do it enough. My first time or two took me about 4 hrs because I didnt know which extensions to use wehre and so on. After a year of detonation problems and changing my plugs 8times....I can now do the whole thing in about 1hr-1:15 every time. I get all the first 3 drivers side from the top, the last one from the bottom of the car(15-20min). Passanger side(45min), i get them allout from the top. Have to have fairly small arms to cram your arm between the stock manifold(if you have headers could be better or worse), oil stick and body of car..but its possible. Also, for the number 2 plug...just remove the alternator, it only takes a min or two and gives you more room to move your arm and wrech around, however, there is still tubing in the way. Youll need to find the perfect size/combination of socket/wrench to get it. After a few times...youll be able to do it in no time. They key to doing it really fast is remembering which tool/socket setup to use on which plug. My first few times...i spent hours trying to figure out which ones too use. Also, a little stubby wrench helps a lot for some of the the passanger side ones. One more thing...ive found that for some of the ones on the passanger side...its easier to almost lay on the engine and use your left hand(even if its your weak one). It give me much better angle to get some of them out/in then standing and working from the side. Like mentioned above, youll have tons of little scratchs/brush burns on your amrs when your done. Have fun, lol...Good luck.
Old Jul 22, 2003 | 12:03 PM
stewmeistr's Avatar
Wink
30 mins.. Man I love the aftermarket K member.
STEW
Old Jul 22, 2003 | 12:07 PM
STEW
Rub it in!
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
