Lost 5th 6th and Reverse???
Old Jul 23, 2003 | 03:28 AM
InjectedSS's Avatar
me and my buddy were out rollin in his viper this weekend and he doesnt use 5th and sixth very much on the street but when we got on the freeway he went to shift into 5th and it was like it was in neutral! it goes into gear but just does nothing same with 6th! we noticed later that night that he doesnt have reverse now either! 1st thru 4th work just fine though what could cause this? seriously i told him to quick beating on that damn car but dayum i cant believe that he broke a T56! ive got 140k on mine and shes made plenty of ten sec passes and STILL hasnt had one prob yet
Old Jul 23, 2003 | 03:39 AM
D James's Avatar
well This is a shot in the dark, but easy to check. When I went to disconect my CAGS I disconnected the speed sensor one instead, which stopped the skip shift, but I culdn't go into 5th or 6th or reverse, 1 through 4 were fine. Of course it was pretty obvious since the speedo didn't work. But hopefully its something easy and simple like that on your buddys car
Old Jul 23, 2003 | 12:21 PM
InjectedSS's Avatar
come on dude! i said it goes into gear it just doesnt do anything... feels like its in neutral
Old Jul 23, 2003 | 05:31 PM
thewinner's Avatar
sounds like a clutch problem to me. or pressure plate. something is not grabbing or the clutch is just spinning on the flywheel and not transferring the power to the tranny.
just had the same thing happen to me on my beater truck except it was all gears. you could go into all gears, let the clutch out and it wouldnt die, acted like it was in neutral. turned out to be the clutch.
Old Jul 23, 2003 | 11:13 PM
InjectedSS's Avatar
damn playa.. dont no one read my posts!! lol i said it works fine in first thru fourth just not 5th, 6th and reverse
Old Jul 23, 2003 | 11:20 PM
thewinner's Avatar
lol. well i guess its something internal with those 3 gears if the others work.
Camaro_Maniac63's Avatar
Tell your friend to buy a new tranny then.......
Old Jul 24, 2003 | 02:25 AM
InjectedSS's Avatar
sweet! maybe you could buy one for him
Old Jul 24, 2003 | 02:26 AM
SVT Killer LV's Avatar
5th, 6th, and Reverse are on the same shaft, most likely if you lose one of those, you lose them all....
Old Jul 24, 2003 | 06:57 AM
InjectedSS's Avatar
well look who it is damn playa what you been up to
btw i was thinking the SAME THING just didnt know if they were on the same shaft or not! makes sense now im thinking that reverse is on its own fork though...
Old Dec 6, 2004 | 03:40 AM
tanker's Avatar
Re: Lost 5th 6th and Reverse???
I have exactly same problem. InjectedSS, did your buddy find the reason for trannies malfunction? Maybe he tried fixing it. I just posted this with exactly same symptoms
http://web.camaross.com/forums/showt...=1#post2670487
Old Dec 6, 2004 | 04:12 AM
nin97's Avatar
if your buddy can afford a viper he can afford a new tranny
blac94Z
Nov 4, 2015 01:59 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
HAWG
Sep 25, 2015 11:41 AM
