halfway through longtube install and have a couple questions...
Old Jul 22, 2003 | 02:18 PM
lt4 fd's Avatar
Ok I was wondering now that I have the engine mounts un done where you jack that side of the engine up by to install the passenger headers, these are jethots by the way. Also is it ok to install the drivers side header before the passenger just wondering since you have to jack the passenger side up and dont want to crush the headers also it looks like we are gonna have to take the drivers side valve cover off is that normal? oh do you need to undo the trans mount to jack the engine up on one side too?
Old Jul 22, 2003 | 03:29 PM
speed76demon's Avatar
put a block on the jack and jack up the engine from the oil pan
Old Jul 22, 2003 | 04:12 PM
got_hp?'s Avatar
be really careful about jacking up the motor............read the thread i just made (search)
as for removing the valve covers.........i did not have to
my driver side went in from bottom , just removed steering linkage. very easy
my passenger side required removing the starter, and undoing the motor mount and jacking up the motor
Old Jul 22, 2003 | 04:20 PM
thewinner's Avatar
put both headers in from the bottom, that worked for me.
having the drivers side header one while you jack the motor up is fine.
dont jack on the oilpan, use the bellhousing. i didnt need to undo my trans mount.
alphaauto
Parts Wanted
Jan 23, 2015 06:17 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
nautilus
Aug 22, 2002 11:49 PM
