What 02 sensors to use with LT's?
Old Jul 24, 2003 | 01:24 AM
Dragon Racing's Avatar
I just got the headers installed on my car and was wondering what 02 sensors i should use. Will i be ok using the ones for the 93 cars or do i need to swich to a heated 02 sensor since i'm now running long tubes?
Old Jul 24, 2003 | 01:34 AM
Blue96z28's Avatar
yeah it would be beneficial to switch to the heated o2's like on the later model cars, becuase of how far the o2's will be away from the heads now, believe the 96 up obdii's, so you can just ask for those part #'s....I would go with a good set of stock AC's, cromer has the for 37.50ish each, with minimal shipping.
Old Jul 24, 2003 | 01:36 AM
93formula's Avatar
which long tubes are you running? a local with a 93 was running stock o2s with his FLP LTs without any problems. compare the o2 location of the flps with whatever ones your using but i think you should be fine.
Old Jul 24, 2003 | 06:23 PM
I'm running Hookers if that helps any. Thanks for the replies.
Old Jul 24, 2003 | 06:28 PM
HoneyCombs's Avatar
I just installed hooker lt's on my 93 about a month ago and used the same o2 sensors, no problems for so far
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
