How much spring sag do I have after 6 years?
Old Jul 23, 2003 | 09:34 AM
stereomandan's Avatar
I need to replace my shocks. I have a knocking sound over bumps in my front passenger wheel well, and decided it's time to replace the shocks/struts. I plan to get the Bilstein HD on all four corners(9313, and 9314). I have 54,000 miles on my '97 Z28.
Anyways, I always thought of lowering my car, but I'm thinking that my springs may have already sagged a little and I wouldn't notice much of a difference. I was looking at the Eibach pro kit.
Does anyone know how much a Z28 sags after 6 years? I can go out and measure from the pavement up to the metal seem under the door if that would help determine how my stock springs compare to a lowered set.
Also, any comments on the shock selection?
Thanks.
Dan
Old Jul 23, 2003 | 10:30 AM
Well, I just measured my door height. The bottom front of my door is 10.1" off the pavemant. The bottom rear of my door is 10.5" off the pavement. I measured with the door closed, and just help a ruler with one end on the ground, and the other end next to the door so I could see right where the bottom of the door was.
If anyone has time to measure the height of a lowered car, like with Eibach pro springs, or similar I would GREATLY appreciate it.
Thanks,
Dan
Old Jul 23, 2003 | 10:38 AM
wiked95ta's Avatar
I'll have to do that on my lunch hr, i'll let you know.
Old Jul 23, 2003 | 11:26 AM
Z Power's Avatar
I know mine have sagged, but I have a 10 year old car. It has probably dropped a good .5-.75 inches, hell maybe even more. All I know is that it doesnt look a like a 4X4 anymore, and most people think I have lowered it
Old Jul 23, 2003 | 01:47 PM
wiked95TA,
Thanks. Let me know when you get the numbers.
You have your car lowered right?
Dan
Old Jul 23, 2003 | 05:34 PM
wiked95ta's Avatar
My car is stock height with 16x8 rims stock tires.
It was off the ground 7.5inches at all 4 corners.
Old Jul 23, 2003 | 05:46 PM
1msfyter's Avatar
Go with the DMS springs(do a search here) awesome springs.
Perfect height and rake.
http://www.fasterbaby.com/images/sbimages/open.jpg
Old Jul 23, 2003 | 05:53 PM
wiked95ta,
Where did you measure? It can't be the same place I did. That would be a 3" difference(more than any lower kit available)
I measured from the pavement to the bottom of the actual door.
Old Jul 24, 2003 | 09:51 AM
wiked95ta's Avatar
I measured it to the bottom of the trim, which is about 3 inches or so high so it'd be about 10.5 inches.
Old Jul 24, 2003 | 11:46 AM
Thanks Wiked95TA,
Sounds like it's the same for us two.
Anyone with a lowered car want to measure? I don't want to lower the car any if I won't see much difference.
Dan
95chwagon
Jan 13, 2015 09:19 PM
Dec 1, 2014 08:08 AM
Chris 96 WS6
33
Sep 3, 2002 09:48 PM
