driving in deep water...
Old Jul 23, 2003 | 09:44 AM
slverbullet's Avatar
ive noticed that whenever i drive through a decent size puddle, that my power steering kicks off. i have no idea why it would do this. i have a cold air intake, but i dont think the water level is high enough to be reaching it. and it is only while driving in water. any ideas?
note: i dont make it a habit of driving through puddles. its been raining a lot here in the florida panhandle and builds up a lot on the roads and especially in turning lanes. i try to avoid these as much as possible. however, sometimes its unavoidable.
Old Jul 23, 2003 | 09:49 AM
Camaro_Maniac63's Avatar
I think what you are describing is called "hydroplaning", that is when you drive through lets say a puddle or something, and the tires lose contact with the road momentarily due to the rise of water and you going too fast, and the steering wheel kicks and the car will pull towards the puddle. Keep both hands on the steering wheel when it is raining in Florida, hydroplaning can get very dangerous.
Old Jul 23, 2003 | 09:54 AM
LWillmann's Avatar
Depending on how deep the water is, I guess it could be that the water is putting enough pressure on the wheel to make it extremely difficult to turn, even with the power steering.
Kinda like it's harder to breath when you're in the swimming pool than when you're out.
Old Jul 23, 2003 | 10:11 AM
AndyCLT1's Avatar
Here's my two cents, the water may be splashing up on the serpentine belt and causing it to slip for a second or two. When your belt slips it won't turn the power steering pump.
Andy
Old Jul 23, 2003 | 10:20 AM
stereomandan's Avatar
Yeah, I was going to say water on the belt too. If you aren't getting assist, that is the reason.
If you turn the wheel, but the car doesn't turn, it's hydroplaning.
Dan
Old Jul 23, 2003 | 10:21 AM
okay, i understand hyrdroplaning and i know its not that. i actually just thought of something else to add. the check guages light comes on when this happens. also, it can happen going through at a relatively moderate to slow speed. also the pump will shut off for ~5-10sec. the first time couple times it did it, i assumed that the pump was going out. then it never did it again. so i left it alone. then i started noticing it did it only when it was raining and i was going through some decent size puddles. any of this help? thanks guys.
Old Jul 23, 2003 | 11:13 AM
The check gauges light might come on because you have momentarily lost the belt pull to the alternator, too.
Old Jul 23, 2003 | 11:27 AM
revtime's Avatar
Be careful with that CAI in deep water your motor can suck water into the intake and engine damage can occur.
I have the splash guards off my Z with a K&N CAI and I avoid standing water like the plague.
Just a heads up.
Old Jul 23, 2003 | 12:28 PM
Red96Lt1's Avatar
Andy
My 86 blazer did the same thing after I took the fan shroud off. That's what I think it would be.
Old Jul 24, 2003 | 01:32 AM
93formula's Avatar
yeah water on the belt, do you still have your silencer on? if your cai sucks water up it usually falls into the silencer. we were working on a buddys car that had a cai and he went thru puddles often, well the silencer had quite a bit of water in it, problably saved his motor from hydro lock.
WildRidez
Feb 23, 2015 07:24 PM
NewsBot
Feb 6, 2015 05:00 PM
Cam's maro
Jan 30, 2015 09:21 PM
Moshbmx1
Jan 20, 2015 03:27 PM
Donwest22
Parts Wanted
Jan 14, 2015 03:56 PM
