Traction Control on 97 Formula
Old Jul 23, 2003 | 09:40 PM
camarokid2003's Avatar
I dont know if i have traction control on my recently purchased 97 Formula. If I turn the car on a Trac low light appears in the dash. Does this mean I have it and if so how do I turn it off.
Old Jul 23, 2003 | 09:52 PM
stereomandan's Avatar
No, that doesn't mean that you have it. If you have it, you will have a little switch under the radio I believe to shut it on/off.
I don't have it and the low traction light comes on now and then, when I have low traction.
Old Jul 24, 2003 | 03:47 PM
Thanks man, that info helped a lot.
Old Jul 25, 2003 | 12:52 AM
96LT14u2Nv's Avatar
look under the hood, if u have a big black box on the drivers side valve cover, u have traction control. if not, u dont have it.
Old Jul 25, 2003 | 04:19 PM
MikeTR's Avatar
I have a 95 Formula & my traction control button is on the console right next to the "Performane" button for the trans. Camaro's don't have a performance mode....they are always in performance mode. If you don't have the Traction button, you probally don't have it....Does the light go out once the car is running for a few seconds? If it comes on & stays on, it sounds like you have a sensor problem in the rear. The low traction light should only come on if you happen to be spinning the tires or when you first start the car up.
Quickss96
Jan 29, 2016 05:56 PM
Henson071
Aug 4, 2015 09:32 AM
MikeWhitener
Aug 2, 2015 06:17 PM
Jcastro2333
Jul 27, 2015 09:49 PM
Boss002
Jul 24, 2015 10:47 AM
