coolant light wont go off
Old Jul 22, 2003 | 03:28 PM
drbling's Avatar
Question coolant light wont go off
again, 1994 z28, 155k miles.... The coolant light came on. I flushed the system twice, which turned the light off for a short time. It then came back on, I reset the computer and it continuest to burn. Anybody know where the sensor is? Anybody ever replaced one? Difficult ? Thanks, Mark
mcj@hiwaay.net
Old Jul 22, 2003 | 03:31 PM
burnemonm1's Avatar
just out of curiosity, did you blead the system?
Old Jul 22, 2003 | 03:32 PM
96HealyZ28's Avatar
hey there, I got the same problem, bad sensor was the diagnosis. If you get more info on it, can you send it to me if you dont mind, if not its cool.. Thanks
Old Jul 22, 2003 | 03:35 PM
drbling's Avatar
I drained the coolant from the drain valve in the bottom of the radiator in front of the passenger's side wheel, and let the engine idle as i refilled at the top and let it drain at the bottom. I repeated the process before refilling with coolant and calling it quits.
Old Jul 22, 2003 | 03:38 PM
anasazi's Avatar
http://web.camaross.com/forums/search.php?s=
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
warmeck
Apr 16, 2015 05:50 PM
captcorvette
Mar 7, 2015 12:37 PM
MattFick
Feb 15, 2015 10:16 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
