Will Ford 35# injectors work with LT1?
Old Jul 22, 2003 | 02:07 PM
thewinner's Avatar
I have a chance to get some of these 35# ford fuel injectors for pretty cheap, they have a brown top. Do these work with LT1s?
Old Jul 22, 2003 | 03:34 PM
Z95m6's Avatar
i know ford 30 and 36 lbs. work cause i have a set of 30's in my car. I assume you meant 36 lb. injectors i have never heard of 35's before.
Old Jul 24, 2003 | 04:55 PM
thewinner's Avatar
ttt, these are brown top injectors, off the mustang turbocoupe i believe
Will they work?
Old May 10, 2004 | 11:57 AM
med_reject's Avatar
these are 35# injectors, i am also wondering if they work. They come in sets of 4s.
taken from an ad:
35 lbs/hr fuel injectors as used in Mustang SVO, 87-88 Tbird turbocoupe, and Merkur XR4TI. These are Ford # E5ZE-A3B, and are a low impedence injectors
Old May 10, 2004 | 12:13 PM
NBred94's Avatar
never mind, I just re-read the last post.
I actually had an 86 SVO when I was in high school. Fun car when it ran right.
Old May 10, 2004 | 12:15 PM
med_reject's Avatar
can buy two sets, sometimes they are real cheap on ebay
Old May 10, 2004 | 12:28 PM
RCF925's Avatar
If those are really low Z injectors they won't work unless you have a converter box because the stock injectors are high impedance.
Old May 10, 2004 | 05:22 PM
med_reject's Avatar
what is a low z injector? are the 35s much different than the svo 30s (other than the fact that they are 35s?)
Old May 13, 2004 | 03:34 AM
med_reject's Avatar
8 of these are availabe on the net, has anybody tried them in an lt1??
Old May 13, 2004 | 03:46 AM
97WS6SCharged's Avatar
If these are low Z injectors, don't try it or you will burn out your injector drivers.
Old May 13, 2004 | 05:20 AM
disco192's Avatar
Just remember that you need high impedence injectors. Its kind of like running 1ohm speakers on an amp that isnt 1ohm stable. You will fry the amp. Same concept.
oldschool
Feb 9, 2016 09:21 PM
NewsBot
Dec 3, 2014 12:30 PM
nophix
Nov 30, 2014 10:26 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
