Loose drivers mirror
Old Jul 23, 2003 | 01:09 PM
coolgenner's Avatar
Unhappy Loose drivers mirror
Hey all,
anybody else had a drivers mirror that shook like crazy when driving? Not the whole assembly, just the glass part. When I drive it shakes pretty bad and look over at the passenger mirror and it is rock solid. Help!
How can fix this? Can it be fixed?
Thanks,
Rusty
Old Jul 23, 2003 | 01:19 PM
Bastardcat's Avatar
There are 3 screws that hold the mirror assembly in the housing. It sounds like you just need to tighten them up unless the actual mirror portion has come loose from the rest of the assembly.
Old Jul 23, 2003 | 03:31 PM
jeremyferguson's Avatar
Mine has done that ever since I had the driver door replaced after a deer hit me(thats right, I didn't hit her, she hit me). This thing jumped head first into my fender and her *** came around and slammed into my door(instantly laying a fat streak of sh*t down the side of my car.....). I almost had some sh*t on my drivers seat too, J/K. Anyways, I think the guys in the body shop just didn't tighten the screws enough when they put the old mirror on the new door.......sorry, I just had to share the deer story.
Old Jul 23, 2003 | 03:37 PM
zuluman13's Avatar
mine shakes alot too when im listening to music with stock stereo too
Old Jul 23, 2003 | 04:00 PM
quicksilver97ta's Avatar
Same problem here with new mirror installed at dealership.
So Bastardcat, once you remove the interior plastic piece are those three screws accesable?
Old Jul 23, 2003 | 08:02 PM
BennyBoy's Avatar
There are 4 parts to the mirror. The glass, the motor, the mounting bracket, and the housing. The bracket is bolted to the door and screwed into the housing. The bolts are accessably when you remove the triangular piece of plastic inside the door. The mirror needs to be off the car to get to the screws that attach the bracket to the housing. The motor screws to the housing as well, and to access these screws you need to either position the mirror out of the way or pull the mirror glass right off. The last piece of the mirror is the glass. This just snaps in to some clips on the motor.
I would pull the mirror right off the car if you plan on pulling the glass off. It takes quite a bit of force to clip the glass back on, and I don't think the mounting bracket is that strong. They don't sell the mounting bracket by itself, so I would save the potential hassle and cost of getting a new mirror assembly by just removing the whole thing if you are going to pull the glass off.
Old Jul 23, 2003 | 08:39 PM
ChickenScreamer94's Avatar
Mine shakes too It sucks when i am on the interstate since it is hard to see people behind you. It is most likely due to an accident a few years ago on my car. Get ambitious and fix it. It is worth it if it annoys you. Good luck
Old Jul 23, 2003 | 10:29 PM
caliking97's Avatar
I heard that the mirror portion just snaps off. You have to be careful though not to break it. Just adjust the mirror all the way out and stick your fiingers behind them and pop it out.
Old Jul 24, 2003 | 07:46 AM
Bastardcat's Avatar
I was able to get to the 3 screws that hold the mirror assembly (mirror/motor/bracket) to the housing just by moving the mirror around.
guruerror
Dec 12, 2020 06:32 PM
Fatdog2
Jan 24, 2015 12:08 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
