Need help for an answer
Old Jul 23, 2003 | 09:10 PM
Canadian z28's Avatar
Ok i've been told that my car runs strong, but for some reason i think there is something wrong with it.
My times at the track are 14.1 @ 100 mph with 2.4 60 foot. However my times can go up to 14.6 (i think cause that's my 8th run in a row)
But the problem i have is at the end of the track the car feels very fast after i finish the 1/4 and then touch the gas again. I've also notice that on the highway if i leave it high reving in a gear for a couple seconds then gas it the car goes like anything, but if i down shift then hit it, it doesn't feel as fast as when i wait a couple seconds in that gear. could it be the fuel pump??
I've done plugs, wires, fuel filter, coil.
It's a 95 with 55,000 miles on it
Old Jul 23, 2003 | 09:24 PM
Pandamonkey's Avatar
I don't know man.......those are some realistic decent times for your car....
As far a the feel - I believe it's just a seat of the pants feel.......if you watch your speedo, you'll probably acheive a high speed if you shift into the next gear rather than hold the RPM's high.
Old Jul 23, 2003 | 09:30 PM
IrocManiac's Avatar
If you had a good 60 ft time you'd be knocking down 13.80s...thats pretty impressive...Could be the pump...but I don't know why after a couple seconds in the gear it would decide to pump fuel a little better???
Old Jul 23, 2003 | 10:17 PM
Yes i know my 60 ft suck. my next mod should be driving lessons
My car has a cat back, lca, eibach pro kit.
I heard that LT1's run very bad when they are hot, that would explain my times going down after 6 straight runs right?
Old Jul 23, 2003 | 10:31 PM
IrocManiac's Avatar
Yes it could...although honestly my car runs good even when its hot...but its definately down a few ponies. I made my run it was 72 or 73 degrees that night...shoulda been 13's if I could launch for ****.
Daluchman1974
Sep 11, 2015 06:12 AM
cmsmith
Aug 9, 2015 07:30 PM
michaelzilinski
Jul 31, 2015 08:41 AM
NewsBot
Jul 29, 2015 08:10 PM
Latronaxe
Jul 20, 2015 12:00 PM
