Is it just me (zip ties and tranny cooler)
Old Jul 23, 2003 | 05:20 PM
95 Mystic TA's Avatar
Unhappy Is it just me (zip ties and tranny cooler)
I have finally got around to installing my tranny cooler. I'm 19 and I have had assistance on installing all of my other mods but decided I would try this one myself. (I mostly watched as others did the work) Everything was going smoothly until I got to the sticking the zip ties through the cooler and radiator. I can not get the damn things through the radiator for crap. I get them through the cooler fine, and what feels like a first layer of radiator and then they will go no more. I even tried using a coat hanger to see if I can get it through. Is it just me or should these bastages be this tough?
Old Jul 23, 2003 | 06:40 PM
$hawn's Avatar
Yeah they can be a little tough, but I'm not sure if you know this or not, but you might be pushing it into the front part of one of the fans.
Old Jul 23, 2003 | 07:40 PM
VegasZ's Avatar
It is much easier to put it in if you take the fans off. You will need to trim the ends of the ties so they dont interfere with the fans once they are in. Try twisting on them some while pushing them in.
Old Jul 23, 2003 | 07:52 PM
Janny's Avatar
Take the fans off and for HEAVEN"S sake put those coat hangers away. Hope you didn't damage one of the cores.
Old Jul 23, 2003 | 08:19 PM
mikem94Z's Avatar
I did mine w/ fans on and had no problems.Went in fine
Old Jul 23, 2003 | 08:48 PM
ChickenScreamer94's Avatar
I installed my zip times from the radiator side, or from the other side you are putting them on. I didnt have to remove the fans. I just "aimed" them where they I thought they should be. I only used three ties and it has held fine.
If the tie isnt going in easy that is becuase it is probably hitting the little cooling lines in the radiator. Just go up or down a little to snake through them.
Old Jul 23, 2003 | 09:20 PM
HardcoreRM125's Avatar
Yea , its just hitting the actual lines of the radiator ... get ridda the hanger before you mess it up , if you crack the line youll hafta pull the rad , get it brazed , or get a new one ... not FUN ... I no exactly what your talkin bout tho cause i jsut did a oil cooler on mine ... Take the ties that are givin u trouble out ... slide em up about a 8th of a inch and try again ... eventually youll get past the lil line and go rite between them , then unblot the fans from the plastic retainer thingy their mounted in , and cut the excess off the ties ... O and you DO hafta push pretty hard once the ties are through the AC and starting into the Rad , itll go tho ... good luck
Old Jul 24, 2003 | 08:19 AM
Janny's Avatar
You don't have to unbolt the fans. Just lift out the wholle carrier that they are mounted in. No nuts, no bolts, just lift and drop..
Old Jul 24, 2003 | 10:47 AM
To lift it out tho dont you have to take the plastic shroud off that covers the top of the Rad and AC Condensor ? I could be wrong but i thought they held the fans in too ...
Mikes 1994 z28
Oct 10, 2015 07:55 AM
68camaroboltz
Oct 5, 2015 01:46 PM
CARiD
Sep 30, 2015 05:44 AM
Bxlt1
Sep 29, 2015 03:18 PM
