Dual filter Oil filter????
Old Jul 21, 2003 | 10:04 PM
IrocManiac's Avatar
Guys I'm switching to synthetic on weds...my uncle says to get the dual guard oil filter or whatever its called where it filters the oil twice...I've heard great things about them but I've also heard they adversly effect oil pressure any truth to that?
Old Jul 21, 2003 | 10:14 PM
thewinner's Avatar
whatever it is, sounds like it limits oil flow alot, oil flow > oil filtration to an extent.
motors will live with dirty oil, not with no oil though.
Old Jul 21, 2003 | 10:34 PM
IrocManiac's Avatar
I know that...thats what I don't know...some people swear by these things, but if it cuts oil flow significantly thats a bad thing and I've never used them...I'm leaning towards normal filters at this point.
Old Jul 21, 2003 | 10:38 PM
m0nk's Avatar
Im using a fram duel guard oil filter, I think its the one? Its black if that helps :P. But my oil pressure is 40 idle, and between 40-60 driving around.
Old Jul 21, 2003 | 10:52 PM
IrocManiac's Avatar
UHHHH 40 after its warmed up???? Thats high.
Old Jul 21, 2003 | 11:12 PM
thewinner's Avatar
dont use fram.
use ac delco or k&n. i believe the k&n p/n is HP-2002 or HP-2003, and the delco one is 1218
Old Jul 22, 2003 | 05:48 AM
anaik's Avatar
Here's some good info on oil filters.
http://www.scuderiaciriani.com/rx7/oil_filter_study/
Old Jul 22, 2003 | 10:33 AM
revtime's Avatar
Guys I think he is talking about the dual filter system. One filter goes down to like 20 microns and then a second filter goes down to like 5 microns. Amsoil sells one of these systems and says you can use the same synthetic oil for like 30 to 40k you just change the filters regularly and add whatever the filter change took out.
Kind of elaborate I think unless you have a super high potency engine. On a basically stock motor it would be overkill in my opinion.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
