What is normal fuel pressure PSI?
Old Jul 23, 2003 | 07:18 PM
alex-z28's Avatar
Also if the pressure is below the normal is that due to the bad fuel pump.
Old Jul 23, 2003 | 07:49 PM
41-47psi at idle with the vacuum hose to the regulator removed. A clogged fuel filter could cause lower pressure.
Old Jul 23, 2003 | 07:51 PM
93FBIRDFORMULA's Avatar
The fuel pressure should be around 41-47psi when engine is not running with the key in the on position, and the pressure should drop 3-10psi when the engine is running.
Low fuel pressure could be due to the fuel pump, clogged fuel filter, or clogged injector.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
greenzee28
Mar 26, 2015 09:13 AM
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
