turbo 400 conversion
Old Jul 22, 2003 | 01:42 PM
95 firechicken's Avatar
what all is needed for a turbo 400 swap in to 95 formula
Old Jul 22, 2003 | 02:37 PM
rskrause's Avatar
Moderator
Re: turbo 400 conversion
You might want to do a search.
1. tranny with pan
2. dipstick
3. torque converter
4. shifter
5. tranny cooler with hoses, fittings
6. 2-pedal assy (if desired)
7. vehicle speed sensor (VSS) reluctor and magnet
8. flexplate
9. inspection cover
10. driveshaft with slip yoke
11. modifications to crossmember, tranny mount
12. wiring in backup lights/starter safety switch
13. assorted fasteners
14. flexplate/tranny shield (if desired)
15. method to reprogram PCM to get correct VSS readings
16. modifications to console
17. probably other stuff I forget even though I just did this
Rich Krause
G-BODYT56
Jan 14, 2022 11:14 PM
Kawi
Sep 28, 2015 09:01 AM
cmsmith
Sep 14, 2015 09:09 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
