blown head gasket???????
Old Jul 21, 2003 | 10:42 PM
ebryant1995's Avatar
I just did a opti cap and rotor change,and it ran good for about a day.Then it started missing again.......... i have a 95 ta,symptoms are this,slite mist out of tail pipe,and last night i looked for an arc,there was no arc but the manifold in one spot on the back was red glowing......thanks for any help.
Old Jul 21, 2003 | 10:56 PM
slashz28's Avatar
maybe a plug wire is grounding on the manifold?
Old Jul 21, 2003 | 11:23 PM
HardcoreRM125's Avatar
Keep an eye on your coolant... if that seems to get lower, then it could be the heads. Change the oil , if antifreeze is in it , itll have a milky kinda color too it. Personally i dont think its the head gasket tho because the opti seemed to fix it for a day ? Or maybe it didnt but your mind was playin tricks on you ? lol ... jsut suggesting , not tryin to flame or nething ... If it had a air leak, like a bad one couldnt it cause that ? Like if it was running lean wouldnt it do that ?
Old Jul 21, 2003 | 11:28 PM
it backfired last night and blew fire out the back,so in thinking its running rich. i might be wrong though,any more ideas??????
Old Jul 21, 2003 | 11:43 PM
I was jsut getting ready to post that , that instead of running really lean, could it be pig rich cause that would cause it to do that. Im trying to think what could make it run really rich ... I guess if MAF was out, IAT, MAP, Something else restricting the flow PAST the sensors , so they tell the computer to inject lots of gas for lots of air , then since it would be restricted it would get minor air and lots of gas , hence really rich. However im jsut aimlessly babling on now cause its late and im gonna go to bed so good luck with your car , when you find out what it is , PM me , cuz thats gunna have me up thinkin now lol
Old Jul 22, 2003 | 12:36 AM
94 CAMRO Z28's Avatar
Are you sure you got the correct wires on the correct portion of the new opti? I've heard of people messing this up before and the car runs like crap, backfires, etc.
Aaron
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
