Ball Bearing Oil Gallery Plug??
Old Jul 22, 2003 | 12:33 PM
rob2299usa's Avatar
Question Ball Bearing Oil Gallery Plug??
When disassembling my engine I removed the ball bearing that was pluging the oil gallery so that all of the oil passages could be cleaned properly. After sending the engine out to have all the machine work done, I was suprised to find a small freeze plug in that oil gallery passage. I called the machine shop and they told me it would be fine and that I could use the freeze plug instead, but I want to make sure... should I remove the freeze plug and install the bearing, or will it be fine??
Old Jul 22, 2003 | 11:21 PM
rob2299usa's Avatar
Exclamation
I really need help on this one!!
Old Jul 23, 2003 | 12:23 AM
93formula's Avatar
personally id install the bearing just to be safe.
Old Jul 23, 2003 | 02:21 PM
rob2299usa's Avatar
ttt
Old Jul 24, 2003 | 10:06 PM
arnie's Avatar
nothin' wrong with the freeze plug. If hundreds of thousands of engines say it is ok, that is good enuf for me.
Old Jul 26, 2003 | 01:13 PM
rob2299usa's Avatar
ttt
mark0006
Mar 21, 2015 12:32 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
mark0006
Feb 3, 2015 05:12 PM
Sandersen511
Jan 13, 2015 03:49 PM
mark0006
Dec 25, 2014 09:50 PM
