CAREFUL JACKING UP MOTOR!......please read
Old Jul 22, 2003 | 04:04 PM
got_hp?'s Avatar
just a warning for everyone
like many of us........i had to jack up my motor to install my jethots.
while i was there, i installed a new passenger side motor mount because the factory one was really crushed.
overall i only had to jack it up about 2 inches
now my t56 seems totally screwed..........its VERY difficult to push the shifter into reverse
5th and 6th gear dont exist anymore.........wont let me find either gear.
it shifts fine from 1-2.....but wont shift into 3 unless i are under 2000rpm........if i go over 2000rpm it wont let me back into any gear except 4th, unless i let the clutch out and wiggle the shifter
also, my speedometer only reads 15-20 when im going 40-45
unless anyone knows better...........im guessing that i bent/crushed my shift linkage , and possibly pinched/crushed the wire that controls the speedo.
ill take it to my friends transmission shop asap and find out.
any guesses?
Old Jul 22, 2003 | 04:11 PM
Fastbird93's Avatar
Did you take the shifter off when you jacked up the motor? Couldn't that have gotten caught up on the floorpan and pulled out some?
Old Jul 22, 2003 | 04:13 PM
anaik's Avatar
Did you unbolt the trans from the cross member? That could have caused damage if not.
Old Jul 22, 2003 | 04:14 PM
got_hp?'s Avatar
no i didnt take it off..............i searched to board before doing it, and no one ever mentioned that.
a mechanic i talked to said he had seen this happen before when people jack the motor to change motor mounts.
Old Jul 22, 2003 | 04:17 PM
got_hp?'s Avatar
no i did not........once again........when i searched the forum, it seemed everyone else didnt unbolt theirs.
i think the problem is that i jacked it up too high, other people must not have had to raise theirs as high as mine.
Old Jul 22, 2003 | 04:24 PM
Z95m6's Avatar
i had to jack up my drivers side when i was doing my slp's and i didn't have any trouble. Although after my motor install for some reason my speedo is off by a few miles an hour and it wasn't before so if you find out what is causing that please let me know.
Old Jul 22, 2003 | 04:25 PM
thewinner's Avatar
i highly doubt you screwed the tranny internals up from just jacking the motor/tranny up.
where the hell did you jack it from in order to crush wires?
You mention you had to go much higher than others. Did you have the car high enough in the first place? my car only took an inch or 2 of raising for the LT to clear the head bolt.
I didnt unbolt the tranny mount or shifter when i jacked mine. Also did you replace the drivers motor mount? you should replace those in pairs.
Old Jul 22, 2003 | 04:34 PM
got_hp?'s Avatar
i jacked the motor up via the oilpan, with a piece of wood under the pan.
i jacked it up about 2 inches
i replaced only the passenger side mount........the driver side was in better condition.
Old Jul 22, 2003 | 06:06 PM
got_hp?'s Avatar
anyone have any idea what i did to it?..........or is my guess of bent shift linkage pretty close?
Old Jul 22, 2003 | 06:23 PM
gb95zconv's Avatar
Like someone said earlier.....check the shifter....if it is a stock one it would be easy to screw it up if you put alot of pressure on it.
Old Jul 22, 2003 | 07:31 PM
Is it possible you crushed the wiring harness against the top of the tranny tunnel at the back of the engine?
Old Jul 22, 2003 | 07:44 PM
turbo_Z's Avatar
i jacked up one side of my motor to get the drivers side header in and hasnt caused me any problems.
Old Jul 22, 2003 | 08:19 PM
thewinner's Avatar
i really really doubt you busted up the internals of the tranny. How would that be possible?
Im thinking that you had unseen problems with the tranny before and now they are starting to show. Stuff can happen overnight, my syncro for 6th gear just stopped working overnight.
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
