Best place to remove a quart of tranny fluid?
Old Jul 22, 2003 | 02:59 PM
JAFO1994's Avatar
I had my tranny fluid flushed and they have almost a quart too much in. What's the best place to remove it. One of the lines?
Old Jul 22, 2003 | 03:18 PM
PatriotTA's Avatar
Just remove the fill bolt on the drivers side of the trans and let it pour out until its level with the hole. If you can stick your finger in and feel fluid your fine. Otherwise, there's too much. Make sure your car is level at the time.
Damn, just noticed you have an A4. That might not work.
Old Jul 22, 2003 | 03:20 PM
chasmanz28's Avatar
Re: Best place to remove a quart of tranny fluid?
bring it back where you had it done, make them do it
Old Jul 22, 2003 | 03:24 PM
burnemonm1's Avatar
dipstick hole is pretty easy you can even stick a hose down the tube and pump it out
Old Jul 22, 2003 | 03:32 PM
JAFO1994's Avatar
I had it done over 6 months ago and really don't trust them since they couldn't do it right the first time. I don't have a pump or tube that will fit down the pipe. Just wondering it there's a plug or something on the block of the tranny or a splice in the line I can lossen.
Old Jul 22, 2003 | 03:40 PM
Black_Z28's Avatar
The only other way to remove the fuild other than the dipstick area is to remove the pan. Which means you would have to refill it again.
Old Jul 22, 2003 | 04:01 PM
BennyBoy's Avatar
This is how I did it. I just bought a little pump with a small hose I could stick down the dipstick tube. Very easy to pull fluid out that way. Check the marine section of your local auto parts store.
Old Jul 22, 2003 | 04:04 PM
95 Z/28 LT1's Avatar
Super Moderator
You could try removing the driveshaft and jack up the car in the front. The fluid will run out the DS end.
Old Jul 22, 2003 | 04:53 PM
MentalCaseOne's Avatar
When my tranny got flushed I saw the guys disconect a metalic line that goes from the tranny to my radiator.... hooked it up to a flushing machine that injected new Tranny fluid the the other disconected end of that line..
I am thinking maybe just maybe thats a tranny fluid line that can be disconected to bleed some of the Oil and then if you bleed too much simply ad some more through the tranny dipstic opening...
Marvin
Old Jul 22, 2003 | 06:26 PM
revtime's Avatar
Disconnect the rubber line on the tranny cooler lines that run into the radiator.
This is easier if you have an aftermarket cooler, but can be done with the radiator cooler line.
The top line is return, so I would disconnect the clamp off the rubber hose and let some run out and then clamp it back up. Best done with the car jacked up and done from underneath.
Old Jul 22, 2003 | 08:25 PM
joefreeland's Avatar
I have been told by several ppl that it wont hurt an automatic if its overfull on the stick a little. They said that the worst that would happen is that it would come out the vent.
Brad
Old Jul 22, 2003 | 08:35 PM
what if the vent is clogged up...
there is a fuid level for a reson ya know..
bleed dam excess any way you can.. better safe than .....
Marvin
Old Jul 22, 2003 | 10:38 PM
ONEQUICKTA2's Avatar
Driveshaft
Old Jul 23, 2003 | 07:05 AM
JAFO1994's Avatar
I ended up disconnecting the bottom cooler line to the radiator. Nothing really came out, so I started the car for 2 seconds. It really came out then. I got about a quart to come out in 2 seconds. Worked out good except I missed my bucket and got fluid all over.
Old Jul 23, 2003 | 07:13 AM
scoobysnax83's Avatar
live and learn..... Do the tranny fluid yourself next time. Atleast you'll know weither you did something the right or wrong way.
Victor Lamb
Aug 26, 2017 02:52 PM
jmadoll
May 27, 2015 07:13 PM
BigWil
Mar 29, 2015 12:24 PM
alex5366
Feb 17, 2015 10:43 PM
mattszm6
Dec 14, 2014 07:09 AM
