How do you clean the IAC?
Old Jul 22, 2003 | 04:06 PM
speed76demon's Avatar
Last time i asked i got mixed emotions can i just unplug it and let it soak carb cleaner will that be sufficient enough or should i do more?
Old Jul 22, 2003 | 04:50 PM
Z95m6's Avatar
i would just pull the throttle body off so you can get to it then pull it out and clean it and the tb while you are at it.
Old Jul 22, 2003 | 04:53 PM
Carlos01SS's Avatar
What he said. Get the TB rebuild kit from GM Parts Direct, & clean out your TB and IAC valve, your car will run better.
Old Jul 22, 2003 | 08:51 PM
Do not soak it. That can ruin it. Clean it with a toothbrush and some solvent. Don't push or pull on the pintle.
Old Jul 22, 2003 | 10:39 PM
BennyBoy's Avatar
Uh oh... I just cleaned my TB and IAC this weekend and push/pulled the pintle in and out a few times. What happens if you do this?
Old Jul 22, 2003 | 11:41 PM
Soon, the world as you know it, will cease to exist.
Normally the pintle gets harder to move as it ages. Moving it manually can strip the worm gear. Also, if you alter the position from what it was when it came out, it will not match the last position the pcm had.
If you are not suffering any problems, don't worry about it.
Old Jul 22, 2003 | 11:44 PM
94 CAMRO Z28's Avatar
I had problems with my car whenever I would put in the clutch and hit the brakes hard the rpms would dive down and then come back up just before it would die. I used a small brush and some engine cleaner on it last time the TB was off and it fixed the problem.
Aaron
Old Jul 23, 2003 | 07:00 AM
FRDnemesis's Avatar
There are two kinds of IAC's. 1 style is the push/pull adjustable. You simply measure from the tip of the pintle to the house (bottom of the threads). push it in until you get the required length via the manual, re-install it, and reset your PCM by pulling the PCM fuse.
The second style is the screw in/screw out type. If you attempt to push this one in or pull it out; you will strip out the threads (they are plastic). There are two shafts inside this motor. The one that slides is adjusted electrically by the IAC. The screw in portion is for the mechanical adjustment via the manual. Reset the PCM blah, blah, blah. You get the point.
Jeff
Jeff1904
Jun 5, 2016 05:00 PM
marlar98
Sep 19, 2015 07:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
tdigger9899
Sep 7, 2015 10:56 AM
