What are the symptoms of a bad map sensor?
Old Jul 21, 2003 | 10:48 PM
speed76demon's Avatar
Just wondering b/c im thinkin of changing it to see if it helps my hesitation any
Old Jul 21, 2003 | 10:56 PM
predator's Avatar
when under heavy load likegoing uphill it will hesitate and cut out on ya
Old Jul 22, 2003 | 08:52 AM
Bobbys_97_Z28's Avatar
what about?
what about at idle and off the start...woud a map sensor cause hes??
Old Jul 22, 2003 | 08:58 AM
This question gets asked frequently. Anyone try the search button?
Old Jul 22, 2003 | 11:13 AM
Chris 94Z A4's Avatar
Well, if you can scan for codes, a bad MAP sensor would set codes 33 or 34. I doubt that it is bad as these sensors rarely fail.
Cleaning the throttle body and IAC would probably help a lot with the hesitation, unless you need new plugs.
Old Aug 11, 2003 | 08:23 AM
lillbush5555's Avatar
Angry
same problem
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
99TransAmWS6
Mar 22, 2015 11:00 PM
Fatdog2
Feb 13, 2015 08:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
