Need Help Removing Gauge Cluster
Old Jul 22, 2003 | 04:17 PM
Toast's Avatar
I took out the four screws for the gauge cluster but it won't come out. It feels like it is stuck on the top of the cluster. I don't see any more bolts. How do you remove it??
Old Jul 22, 2003 | 07:23 PM
$hawn's Avatar
You know that large front dash peice, well where it joins the gauge cluster bezel, lift up in that area a little(be carefull not to break it) and there will be 2 7mm bolts holding it on.
Although you got a 97 dash and there a little different from the rest, they may be in a different spot.
mattstrike
Mar 11, 2015 07:33 PM
94Camaro
Feb 28, 2015 03:00 PM
Joes96z
Dec 13, 2014 07:48 PM
CaRParts102
Dec 6, 2014 08:45 AM
