View Full Version : LT1 Based Engine Tech
- compression questions
- Coolant Crossover Tube Seals
- Anyone try Mobil 1 15W50?
- spun rod bearing..
- Will hooker shorties bolt directly
- Question on timing chains...
- PCV valve?
- Do I have OBD I or II?
- 1.7 rockers and 224/236 questions
- Delco spark plug number?
- Damaged wires
- 355ci options
- Skipped timing?
- Coolant in cylinder.
- What O2 extensions do you need?
- Synthetic oil equivalent of 15W40?
- Flexplate to Converter bolts stuck! Help!
- y pipes
- Somebody please..
- DMH Cutout Wiring Help!
- mac headers
- EX-612's
- Help , car running PIG RICH
- anybody has B body stock PCM file, help
- Percy's Dead Soft Al Gasket - install
- Hmm... oops.
- Did topic search. Didnt find Steering Gear answer to my question. Help me real quick!
- KD's
- water pump coolant line... bottom pass side
- Fault in quad driver module.....
- Is Aluminum Powdercoatable?
- cheap LT1 stock rebuild, will this work
- Do MSD Coils go bad quick?
- springs and swaybar for 96 ss?
- Help me make my car faster!!!
- O2 differences?
- Porting lt1 Intake?
- low rpm stumble
- Suspension Gurus needed
- Oxygen sensor problems
- Underbody flush
- Fuel System Issues/AFPR Options
- Crane 99893 springs
- Cam and computer calibration
- Service Engine Soon
- Valve Springs
- My heater just quit!
- What is this?
- Mounting DMH Cutout Switch
- In car video of Z28m6 racing/drag
- Question about Injectors!
- Replacing the belt?
- Cracking Radiator end caps
- no speedo
- 383....Stock rods?????
- Brakes with bigs cams and low vacuum
- Done, But>>>>
- Possible problem with O2 sensors
- 1.6 Roller Rocker question.
- more alternator trouble...
- color inside 30th ann.
- Opti dowel pin protrusion on 95Z?
- Comp 230/236 vs. CC306
- How do i launch with a 300 stall?
- Converter question, not for f-body
- HELP! Exhaust Smell
- popping out of reverse
- Dyno tuning in DFW?
- bolt on Headers
- Rear swaybar endlinks
- Oil leak
- Torque and high rpm
- Head porting
- A.I.R Removal- B-Body guys please look!
- need help diagnosing a noise...
- I need a part #
- I think my project is complete
- Do i need a programmer or what.
- shoebox need help!
- Strange knocking sound... (rear)
- how much power with cam??
- Need help with smog pump and EGR
- car boggs at low rpm??
- Ignition Problems?
- hurst shifter
- Whats gonna work best for me??
- lifters
- Pull out susp. part, sand coating them?
- need keyway cut in hub....
- whats the smallest independent shiftlight out there??
- Water pump bolt size?
- Do I have to drain the coolant?
- Best Cali Emission Headers
- Headers or gears?
- Cams
- Oxygen simulators
- help with xtra cash
- ss hood
- Disable Speedo?
- O2 extension question
- 406 Lt1
- Best anit-corrosion brake rotors?
- Where To Get Lt1 Edit?
- 7deg of knock retard
- Car runs like crap cold? Awesome when hot.
- Super comp shortie headers size?
- Does the Arrow on the Balancer point to the cam pin
- Help with cam/heads
- Electrical problems
- Feels like it's misfiring when I run it hard...
- Block prepping for new heads.
- what are your 1/8th mile times?
- Intake differences
- Mac header people in here...
- Fuel Line Rupture IMPORTANT
- Random misfire
- Has Anyone Used a Comp Cams Pushrod Length Checker??
- will it fit
- 230/236 112 running!! but running hot...
- Miss Fire ???????Please Help
- K&N or Moroso?
- WP Leaking from Weep hole !
- lighter pistons, rods, etc
- rear end question
- oil pan removal
- How much of a horsepower difference between these cams?
- More great work by Lloyd Elliot.
- Need LT4 (preferably) or LT1 .bin or .lt1 file
- Long Tube guys, what setup?
- How much $$ to do a cam?
- Power Steering Cooler
- Help with engine swap
- LT1's -cats or No cats?
- Anyone ordered form racenet.com
- Rear Main Seal w/ paper gasket
- How does my LT1/Borla sound? Rate it for me!
- First Post on Board
- stumbling, cutting out. need help
- A 305 LT1 You are kidding me?
- gear questions, sorry...
- RTV for new shifter install
- No start up???
- Car Died, Please Help
- starter removal
- Car quit. Please Help!
- 7/16th or 3/8th stud for rockers?
- Anything special to know for in-line fuel pump install?
- Drive Shaft Or Gears Howling?
- ZR-1 Rear Wheel
- boxing in stock LCA's....
- 383 stoked lt1 questions???
- Stock Stall + cam
- auto shifter?
- Best cam for mid 12s on stock heads?
- 2.02/1.60's on an LT1..do they work?
- hood latch cable disconnected...how can I get hood off?
- How good are "Sealed Power" Lifters??
- Do the Impy head gaskets really make a worth while difference?
- Camshaft swap parts list
- Spiral Max for LT1??
- Where can I buy Dynomax Bullets?
- What are the best heads for LT-1???
- Cylinder head removal ????
- Brodix heads
- Anyone remember this thread?
- Lt4 383
- Gears
- Opti funny...
- Help!!...Starting issues
- Cheapest place to buy LT4 "hot cam" or equi valve springs?
- Guys with Desktop Dyno 2000....LT1 Intake Manifold/TB CFM max flow rate with 52mmTB?
- Alumalloy?
- LT1 heads help please
- electrical question please help.
- production date?
- White face gauge overlay
- Tire Size
- BBC K-member from BMR...
- aparently the LT1 will in fact start with the throttle body removed...
- Exhaust POLL
- GM part number (lifters)
- Is upgrading from shorties to Long tubes worth the $$ ?
- where to buy an lt4 km
- What are good lifters to use on an LT4 hot cam swap?
- LT4 valve spring swap - accessories
- lt4 km
- Basic Suspension Mods
- 600rwp with an NA LT1 opinions
- Has anyone bought the new black 40 Series Flowmaster??
- Where is the block heater?
- Rear-end lubrication level question.
- gas tank size?
- K&N 3002 oil level ?
- Need Help Fast, Can I run Two Timing Cover Gaskets??
- opti install- Using bolts to pull opti flush?
- Car randomly dies...seems ignition switch related
- A4 to M6 conversion codes
- Easiet way to hook up temp gauge
- 383 ?'s
- what's next
- 2 cam related questions
- Hooker vs Magnaflow
- Cam spec design theory
- 95 shift kit
- desperate need of help
- I need gaskets!!!
- Valve guides and 1.7 RR's
- Front Seal ?
- Rebuilding an Alternator ?
- Stupid question
- I need taller valve covers???
- pro 5.0 install question
- Gas in my oil?
- Oil pressure sending unit
- independent rear suspension?
- LT1 4 bolt ? and Windage Tray?
- anyone replace outer door handles
- Wipers won’t park and washer fluid won’t pump…
- How hard is it to bend the rear axle?
- Cams
- What oil pump do you like?
- fuel pressure release...
- MSD Coil Part Number
- bad stumble at idle
- surging/missing?
- 1LE What is it and do I have it?
- Hub&Bearing
- What springs to use for .600 lift?
- TB Bypass
- low oil pressure after redoing head gasket's
- How to tell if my optispark is dying.>>>
- Afpr ????
- low coolant level light in 94 Z28, need advice
- LT4 knock sensor
- Will SFC's help my times much???
- LT1 passkey system
- question about air intake
- Usaed Macs?
- rear brake rotor install?
- which lt1 head gasket??
- Oil level sensor.....( Canton Oil Pans )
- Tonight, Stock alarm randomly sounds and dome light wont go off. HELP?? (did search)
- A good pair of heads and cam helps me in high altituded places??
- Best LT1 tuning Software????
- Trans Perf Button P/N
- Free / Cheap Mods ?
- I Need A Part Identified
- Rattle noise while revving in neutral, and at low rpms. HELP
