Car Died, Please Help
Old Jan 19, 2004 | 10:31 AM
TArider21's Avatar
Angry Car Died, Please Help
Well the Trans Am is dead once again, heres what I did. I disconnected the drivers side oxygen sensor to do something else to the car, put the car back down, but i forgot to reconnect the oxygen sensor. Started car and car ran fine, took for drive around block, and went wide open throttle with oxygen sensor disconnected, car died at corner, and now it won't start. It is a 1994 Pontiac Trans Am. Need help asap!
Old Jan 19, 2004 | 10:38 AM
Without any more details, the first thing I would do is check fuses under the hood, then check for spark and fuel.
Old Jan 19, 2004 | 12:14 PM
TArider21's Avatar
Thumbs up Car alive again!
Rob, before reading your reply, I went out and bought a new coil because that has been the problem every other time my car wouldn't start. That didn't work, and I took a look at the fuses and the ignition fuse was blown. I wish I would have read your reply before I bought the coil, thanks for the heads up, your info is always appreciated!
Old Jan 19, 2004 | 01:30 PM
At least coils are cheap and it was not something major.
bfmv13trivium
Jan 14, 2015 09:57 AM
ModdedNerd
Dec 18, 2014 10:52 PM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
