Cylinder head removal ????
Old Jan 18, 2004 | 10:25 PM
9T4LT1's Avatar
I'm about to remove the heads on my 94 6 speed and was wondering what the proper procedure was. It doesn't look too fun being that half the motor is under the cowl. Is there anything I should look out for or any tips that might make things easier.
Thanks,
Any help is greatly appreciated.
Old Jan 18, 2004 | 10:29 PM
Zack's Avatar
LOTS of patience. Not too hard. Get the manfiolds off, thats a little frustratiing. www.shbox.com has a good write up for when you are ready to remove the intake manifold. Its under the cam install guide. Im stuck in my removal because of a rounded off head bolt
Old Jan 18, 2004 | 11:28 PM
1FASASZ's Avatar
its verry easy unless you have long tubes in the way like i did but it still wasent bad you should buy a chiltons or hanes manuel they come in handy
This would be some good reading for you.
http://www.afrashteh.com/guide/install.htm
Old Jan 18, 2004 | 11:35 PM
ibanez6rg's Avatar
It's a lot of fun, except for the coolant end of it.
Hey Rob, you think its nessecary to take the knock sensor out? I already took the block drain plug out, but there is more coolant coming out of the lower head bolts on the passanger side. I thought draining the one side would be good.
Old Jan 18, 2004 | 11:57 PM
lt1g3n's Avatar
ty
thanks for the link shoebox, that will come handy when i get ready to install my cam and new heads ;o
Old Jan 19, 2004 | 12:07 AM
Actually, the knock sensor is easier to get out, so yes I would take it out too. Each side drains independently.
Old Jan 19, 2004 | 10:18 PM
9T4LT1's Avatar
Thanks for the links and info guys. I'm going to deffinatly buy a Chiltons so I can have some under hood guidance.
Thanks again.
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Elcojoe
Nov 17, 2014 10:27 PM
