Cams
Old Jan 19, 2004 | 09:47 PM
AdamZ1LE28's Avatar
Exclamation Cams
I'm looking to put a cam in my 96 Z28. I have plenty of bolt ons. I have narrowed my cam search down to the LT4 Hot Cam Kit, the CC305 and the CC306. Obviously the CC306 is the biggest, and will sound and perform the best, but is this just too much for stock heads? What do you guys think I should do? Thanks
Old Jan 19, 2004 | 09:52 PM
ibanez6rg's Avatar
I'd go with the 305 if I were you.
Old Jan 19, 2004 | 09:56 PM
AdamZ1LE28's Avatar
Any special reason why? Is the 306 just too much out of the heads, and the hot cam just wouldnt be enough?
Old Jan 20, 2004 | 09:40 AM
ibanez6rg's Avatar
It really depends on what you're going for in your car. The 306 will work with stock heads.
Old Jan 20, 2004 | 10:03 AM
LS1_03's Avatar
http://web.camaross.com/forums/showt...hreadid=214830
Check out the post I made. Has plenty of info. It comes down to what you can afford. All 3 of those cams will work with stock heads. There are more cams that will work with stock heads as well.
Old Jan 20, 2004 | 01:51 PM
AdamZ1LE28's Avatar
Thanks guys....I will probably be going with the CC306 cam with my stock heads. I will throw on some Hooker Headers, a 58mm throttle body, 1.6 rockers, springs, heavy duty timing set, and all the seals and everything. The whole parts list will cost me around $2100 (uninstalled)...any other parts that should be installed with the CC306 cam?
Thanks in advance
Old Jan 20, 2004 | 02:03 PM
FacelessZ's Avatar
Thanks in advance
Save $300 and don't get a 58mm TB, you don't need it unless you just like that cute little sucking sound it makes with a cai...unless you have a blower, turbo, or A LOT of N20 don't bother with a 58mm TB...the most I'd go is 52mm...
Old Jan 20, 2004 | 02:17 PM
ibanez6rg's Avatar
Especially with stock heads. Hell, I'll be using a stock TB for awhile with my heads/cam setup.
Old Jan 20, 2004 | 02:42 PM
AdamZ1LE28's Avatar
I forgot to mention I'll be getting the Crane Cams Hydraulic lifters. I'll also be getting 1.6 Crane Cam Roller Rockers...do you guys suggest self-aligning or non self-aligning?
Old Jan 20, 2004 | 02:44 PM
FacelessZ's Avatar
http://web.camaross.com/forums/showt...hreadid=215303
Old Jan 20, 2004 | 02:45 PM
ibanez6rg's Avatar
NSA are better. But I would go with Pro Mag's and Comp R's instead.
Old Jan 20, 2004 | 03:25 PM
AdamZ1LE28's Avatar
Yeah the Pro Magnums are cheaper and lighter...thanks for the advice, I will get them. The 1.6 ratio won't require any modifications to my valve covers will they? I will also be getting the high energy pushrods. Thanks again.
Old Jan 20, 2004 | 04:17 PM
ibanez6rg's Avatar
With the 1.6rr's you'll probably have to "gut" your stockers, but they will have enough clearence with the stock valve cover.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
