LT1's -cats or No cats?
Old Jan 19, 2004 | 12:51 PM
SlickBlack Z's Avatar
I was just wondering if it is a myth that mostly stock LT1's make more power with a little backpressure in the exhaust...as provided by cats. Or do off road pipes let the engine make more power?
Old Jan 19, 2004 | 01:14 PM
FacelessZ's Avatar
!cat...don't gut it...
I believe that more horsepower will be made with a car with no cats...straight pipes...
Old Jan 19, 2004 | 01:17 PM
speed_demon24's Avatar
What are cats? I don't see many other bolton A4's dynoing above 300RWHP, infact I don't think I have seen one. I'm not saying I'm the only one, I know there are more out there.
Old Jan 19, 2004 | 01:19 PM
FacelessZ's Avatar
<=== above the 300 mark...
Old Jan 19, 2004 | 01:24 PM
What are your #'s? I dont see them in sig. I'm not saying im the only one, im just sayin my o/r y-pipe isn't hurting.
Old Jan 19, 2004 | 01:25 PM
FacelessZ's Avatar
I haven't dyno'd...but looking around I don't think there's a way I'm still under 300 unless I have a blown head gasket or some unknown leak...
Old Jan 19, 2004 | 01:26 PM
QCKZ28's Avatar
all the backpressure an lt1 needs is headers.
jesse
Old Jan 19, 2004 | 01:28 PM
FacelessZ's Avatar
jesse
Old Jan 19, 2004 | 01:58 PM
How Much louder does the car get with the catylictic converters removed and off road pipes in their place?
Old Jan 19, 2004 | 02:00 PM
FacelessZ's Avatar
Old Jan 19, 2004 | 07:33 PM
D James's Avatar
I ran without cats, and hated it, the smell was pretty bad, plus its bad for the earth, and against the law. I didn't notice any difference with power or torque curve, only time I do notice is with the cutouts open. Now a highflow cat will flow better and is much lighter, so if yours goes bad, I would suggest one of those. As far as any engine needing backpressure-its all myth. backpressure is gas going back towards the heads into the valves, if really bad. Exhaust pipes can create a scavaging effect which pulls out the exhaust better than it could normally do, but keep in mind it must be set up right, headers also work with this principle in mind. If engines worked better with pipes attached you would see hotrod dragsters running them, not open headers. Exhaust systems can change the rpm range of torque higher, thus some people think it goes away without pipes, when in reality it is still there. Just like a large cam gives more power, but bottom end may sacrifice. Many times a freeflowing exhasut will give more torque evenat a low rpm
Old Jan 20, 2004 | 01:30 PM
I already have high flow cats...FLP's
Old Jan 20, 2004 | 01:35 PM
Hyperspeed97z28's Avatar
No cats here !
Old Jan 20, 2004 | 02:09 PM
LT1WanaBe's Avatar
I disagree... the computer wouldnt pick anything up and send the EGR system all out of whack... thats one thing the EGR is dependant on
Old Jan 20, 2004 | 02:10 PM
LT1WanaBe's Avatar
