car boggs at low rpm??
Old Jan 20, 2004 | 12:55 AM
ram air camaro's Avatar
question #1 ...
it has a miss at low rpms right in between 45 and 55 mph some times i could here something pop through the exhast or intake??? 94 camaro lt-1 a4
i've recently installed??
230/236 cam 112 lsa
3000 street fighter converter
1.6rr
pcm for less tuning
i still have the stock 3.23's
question #2
oh i also got a oil leak that i cant find, i think its the rear main seal or the intake manifold??
i feel like i should be in the high 12's but really sure i'm at high 13's
Old Jan 20, 2004 | 01:56 AM
Wild1's Avatar
Intake / Vacuum leak...
Also check/clean your IAC
Old Jan 20, 2004 | 05:43 AM
slopokrodrigez's Avatar
Do you still have the EGR? They're good for low rpm stumble. Also see if the vac hose to the FPR is wet.
As far as the leak is concerned, if it is external. Clean the block real well where you suspect it's leaking and put die in the oil. UV light and usually sun light make it glow. Don't forget if you don't see drops of oil on the drive way but your oil is going down, you could have a leak internal.
Old Jan 20, 2004 | 06:14 AM
IslandZ's Avatar
I think mine is so what does that mean? wet with fuel right?
Old Jan 20, 2004 | 06:46 PM
intake leak
well when i put the intake manifold on i put the original gasket and i used silicone because i was in a hurry to get the car going that i didnt want to wait for the gasket . the uv light is a good idea i have one from a ac kit i bought last year. what do you guys think if i check vacum and how to check it ?? any more suggestions.. thanks for the replys
Old Jan 21, 2004 | 12:40 AM
fozziez28's Avatar
your problem sounds like mine. I have an oil leak i have to track down too. mine is plug wire arcing. (missfire on cylinder 2 and 6). more details to come once i get working on it. -Michael
Old Jan 21, 2004 | 12:59 AM
plugs and wires didnt cure mine mine was also arcing cured that though.
Old Jan 21, 2004 | 01:20 AM
bdc95ta's Avatar
your fpr is bad you need a new one
97SSdude
Dec 31, 2014 07:43 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
