Question on timing chains...
Old Jan 20, 2004 | 09:31 PM
CeeBee94Z's Avatar
I have a 94Z that I plan on doing the hot cam kit in the near future and was just wondering what the best bet is for a timing chain replacement while I am in there?
Do they make a timing gear set for the LT1's? Any help is greatly appreaciated.
Old Jan 20, 2004 | 09:39 PM
ibanez6rg's Avatar
You have a few options. You can either keep the 94 setup and buy a Lunati chain (against that).
Convert to 95+ and either run a Cloyes double roller or LT4 HD. If you're keeping the stock waterpump, you'll have to run the LT4 HD.
Old Jan 20, 2004 | 09:48 PM
CeeBee94Z's Avatar
Yea I am going to be using the stock WP, I am replacing it, but it will still be the stock one. Do you have an idea of how much the LT4 HD chain is? I am trying to get a total amount for the kit and all the extra parts and gaskets I need.
Thanks again for the help
Old Jan 20, 2004 | 09:51 PM
AsianSensation's Avatar
You will have to do a vented opti conversion if you plan to use the LT4 ED timing set. That's alot of $$$ just to use the LT4 ED timing set.
Old Jan 20, 2004 | 09:55 PM
CeeBee94Z's Avatar
Yea I would rather not do the vented opti conversion, thats why I am trying to get the correct parts that I need the first time without spending a ton of money, but I obviously wanna do it right.
Thanks guys
Old Jan 20, 2004 | 10:03 PM
ibanez6rg's Avatar
If your staying with the 94 setup. Stock or Lunati are your options.
Old Jan 20, 2004 | 10:32 PM
CeeBee94Z's Avatar
You wouldn't happen to know the part number for the Lunati would ya?
Old Jan 20, 2004 | 10:35 PM
http://www.97ta.com/useless_folder/lunatitiming.jpg
Old Jan 20, 2004 | 10:38 PM
94formulabz's Avatar
I'd stick with the stock one, the LT4 is mucho dollars. It is an obvious time to make an upgrade, but how often do you see posts "broken timing chain " .....not to often.
that was my rationale anyways.
-brent
Old Jan 20, 2004 | 10:44 PM
Jay-Roll's Avatar
Sorry to chime in on your thread but I have the same question. I want to keep everything the way it is on my 95' Z. IE water pump,opti.,etc. So which timing chain to go with and what's the price?
Old Jan 20, 2004 | 10:55 PM
CeeBee94Z's Avatar
Thanks for the help guys. The only thing I worry about with replacing with a new stock chain is that if I bump up the rev limiter will I run into problems on a stock chain?
Thanks again
Dunno the abosolute best but my LT4 ED timing set cost $200 from Sam Taylor.
Old Jan 20, 2004 | 11:44 PM
CeeBee94Z's Avatar
Another question....
on shoebox's site it says to replace the opti o-rings....where can I get those?
Old Jan 21, 2004 | 06:04 AM
Mtrhds94Z's Avatar
Opti Drive Shaft Orings GM 10474278
Get 2..
Feffman
Oct 9, 2015 05:42 AM
sscott
Jan 17, 2015 04:30 PM
capebuf
Jan 13, 2015 07:22 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
