Opti dowel pin protrusion on 95Z?
Old Jan 20, 2004 | 11:29 AM
BlownF1's Avatar
Question Opti dowel pin protrusion on 95Z?
My builder has the short block almost finished and I need to verify how far the opti drive pin sticks out. If I remember correctly from when we measured one on a buddies car, it's about .600"? I'm talking about how far it sticks out once you remove the opti, NOT the length of the pin itself. Can anyone confirm? Thanks!
Old Jan 20, 2004 | 12:49 PM
Don 97 SS's Avatar
GMPP says dowel max length from face of cam is .620"
(DynaSpark says .605")
The dowel max OD is .250" if you had to hammer it in and it mushroomed.
Old Jan 20, 2004 | 02:38 PM
BlownF1's Avatar
Thanks, I'll pass those numbers along to him! Much appreciated...
Old Jan 20, 2004 | 06:51 PM
My stock pin was .650 in length from the face of the cam (and looked like it could have been longer without a problem).
Old Jan 20, 2004 | 06:56 PM
Brandon 95 Z28's Avatar
Mine was about ~ .650 as well, and was not too close to bottoming out.
Brandon
Old Jan 20, 2004 | 07:17 PM
Don 97 SS's Avatar
Be careful when installing an aftermarket cam (yeah, I know most cams installed are aftermarket ) because they can have wildly different length dowels compared to your oem cam dowel. A dowel that is no more than .620" will work just fine. Too long of dowel (and I don't know how long) will definitely shorten the life of your Opti's bearing. This is a critical fitment and I'm not sure how consistent the tolerances are on Opti's housings either. I hear they can vary.
Old Jan 20, 2004 | 08:52 PM
Yeah, my Comp Cams pin was .840" .
reww86
Aug 29, 2015 06:04 PM
Schul365
Aug 22, 2015 10:00 AM
War Engine
Aug 20, 2015 06:13 AM
asilomar244
Jul 12, 2015 05:53 AM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
