Block prepping for new heads.
Old Jan 19, 2004 | 05:43 PM
ibanez6rg's Avatar
I should be getting my heads back sometime mid-week and I've searched on block cleaning but didn't really come up with anything good.
What do you guys recommend? I know not to use ScotchBrite or anything metal wise. Just need to know the best way to get gasket material off and get it clean.
Also, being the block is drained of coolant. What's the best way of refilling it? I'll be installing an electric w/p, will I be able to fill it back up with that while the car is off?
Old Jan 19, 2004 | 05:53 PM
polcat1p's Avatar
I used the 2'' blue scotchbrite pad on a drill on the exhaust ports on the heads. i heard it wont remove the soft aluminum. I also used it on the block. I went through like 6 of them. Worked like a champ.
Old Jan 19, 2004 | 08:59 PM
AsianSensation's Avatar
I used a gasket scraper on the block and some brake cleaner. I filled my block through the water pump housing. Since I have a Meziere, I gave it power to circulate the coolant thoughout the block.
Old Jan 19, 2004 | 09:12 PM
94TA_LT1's Avatar
be sure to clean out all the bolt holes and retap them. Also napa makes a gasket removing solvet-it works well
Old Jan 19, 2004 | 09:35 PM
ibanez6rg's Avatar
Retap them?
Old Jan 19, 2004 | 09:50 PM
Brandon 95 Z28's Avatar
So far I have just been using a gasket scraper, and some cleaning solvent, it has been going ok. I was also wondering about the threads, and if i should do anything with them, and how I would do it.
AsianSen- Did you just poor coolant into the waterpump through the thermostat housing with it removed and run the pump??
Brandon
Old Jan 19, 2004 | 10:35 PM
94_Z28_guy's Avatar
It is just to clean out the threads from the old thread sealant. I guess it could affect the torque readings when you put the new head bolts on/in.
Just screw a tap in by hand into each head bolt hole on the block. I used a 7/16-14 tap.
Old Jan 19, 2004 | 10:39 PM
Brandon
Yep, that's what I did and pour coolant in the radiator also.
Old Jan 19, 2004 | 10:43 PM
A thread chaser is recommended over a tap. A tap can remove more metal, but a chaser won't. That said, I have used taps before (just because I already had them) and never had a problem.
Old Jan 19, 2004 | 11:17 PM
LT1 Bunny's Avatar
Originally posted by ibanez6rg
Retap them?
Chase the threads, you dont want to run the risk of removing more metal "accidentally".
Oops, sorry shoebox! I should have read the thread all the way through!
Old Feb 13, 2004 | 03:00 PM
ibanez6rg's Avatar
Thread chaser, what size?
Old Feb 13, 2004 | 03:43 PM
If a the tap someone said they used was 7/16"-14, don't you think the chaser would be the same size? Maybe not. I guess that is why you asked.
Old Feb 13, 2004 | 03:59 PM
ibanez6rg's Avatar
Never even saw the post stating it, oh well.
CARiD
Sep 30, 2015 05:44 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
heus
Sep 8, 2015 12:01 PM
