Replacing the belt?
Old Jan 20, 2004 | 02:38 PM
SPEEDYGUN's Avatar
Replacing the belt?
How do you replace the belt on a 97 LT1? Is there a tension pulley?
Old Jan 20, 2004 | 02:45 PM
AdamZ1LE28's Avatar
Yes the tension pulley is down on the bottom of the motor by the crank pulley. Just put a wrench on there, 15mm i think, and turn it to the right. The belt will loosen right up and you'll be all set.
Old Jan 20, 2004 | 03:36 PM
96LT1TX's Avatar
13mm on my car... tighten till belt tensioner comes down, then pull belt off, and replace.
Old Jan 20, 2004 | 06:49 PM
Tensioner
Also 13mm on my car.
Old Jan 20, 2004 | 06:51 PM
AsianSensation's Avatar
Time for a new rachet Rob.
Old Jan 20, 2004 | 07:10 PM
What? You don't tape up your ratchets?
Magenta_Hearts
Mar 29, 2017 08:54 PM
grabbem88
Feb 23, 2015 09:41 PM
dale3in98
Feb 14, 2015 12:18 PM
1LEThumper
Jul 14, 2003 12:45 PM
