How much of a horsepower difference between these cams?
Old Jan 19, 2004 | 02:51 PM
BottleFedZ28's Avatar
XE 230/236 .544/.555 112
XE 230/236 .578/.595 112
Basically the first cam is with 1.6 rockers and the second one is with 1.7 rockers.
I'm building a 383 with stage II heads that flow 260cfm@.550 lift and 268cfm at .600 lift.
How much of a hp difference will there be between the two rockers?
Old Jan 19, 2004 | 03:04 PM
Josh-'04 GTO's Avatar
10-12 horse...tops. IMO, you need better heads. Not saying that your engine won't run well and make good torque, but horsepower won't be optimum without better heads. I would shoot for a good 20-30 cfm more of intake flow. How does the exhaust numbers look?
Old Jan 19, 2004 | 03:12 PM
I don't remember the exhaust numbers but I know this guy's flowbench reads a bit low. There are guys with heads that flow the same as mine that run 11s on the identical cam in Vancouver at sea level.
Is that 10rwhp or flywheel?
Old Jan 19, 2004 | 04:34 PM
N2OpwrdTA's Avatar
It all depends. If your heads are still flowing good at the higer lift, then go with those. If they get turbulant or flow stalls harcore then go with the smaller lift.
FWIW, when I change lift on desktop dyno and the rate a where heads flow...at best it only seems to make for a few hp under most circumstances. There are exceptions to everything though.
Old Jan 19, 2004 | 05:29 PM
97Z-M6's Avatar
its not worth 10 hp (if you get that depending on your heads) to chance thowing your valve train geometry off.
Old Jan 19, 2004 | 06:47 PM
That's why you check for correct pushrod length...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ChrisFrez
Mar 1, 2015 01:33 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
InfernalVortex
Jan 17, 2015 09:35 AM
