Valve Springs
Old Jan 20, 2004 | 03:54 PM
AdamZ1LE28's Avatar
Valve Springs
I'm planning on putting the Comp Cams 306 cam, their 1.6 Pro Magnum Rockers, their High Energy Pushrods, and all the seals and all that good stuff....but what valve springs should i use with this set up?
Old Jan 20, 2004 | 04:01 PM
96LT1TX's Avatar
www.cmotorsports.com
check out their ex components 612 valvesprings, I have em on my car and they work money so far... supposedly good to .620"
Old Jan 20, 2004 | 04:02 PM
BUBBA's Avatar
Go to the CC website and look at the cam card specs for that cam. It will tell you the specs of the recommended springs.
Old Jan 20, 2004 | 04:12 PM
FacelessZ's Avatar
Crane 99893 dual valve springs are supposed to be great springs and don't require any seat machining whereas the Comp 987's do...
The 612's are a great single spring, but for a little bit more you can have the peace of mind with Crane 99893 dual springs...
I'd go 612's for the price or 99893's for the strength...
Old Jan 20, 2004 | 04:13 PM
ibanez6rg's Avatar
I'm running Comp 987 double springs.
Old Jan 20, 2004 | 04:50 PM
BUBBA's Avatar
Never mind. I see their Cam Card doesn't show spring pressures.
Old Jan 20, 2004 | 05:53 PM
rskrause's Avatar
Moderator
Comp recommends the #986 or #987 for the 306 series cam. The 986 is 132# @ 1.750" and 280# @ 1.250" with a rate of 296lb/in. The 987 is 121 @ 1.800" and 388 @ 1.200" and a rate of 344lb/in. Any spirng in this range should work fine.
Rich Krause
Old Jan 20, 2004 | 06:34 PM
jonaddis84's Avatar
Id recommend comps 946 triple springs, closed 353lbs, open 835lbs
haha, jk, listen to faceless and rich
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
