hood latch cable disconnected...how can I get hood off?
Ok, I've done it now. I've done somethin I can't fix. The latch is connected on the hood, and the cable is disconnected from the latch. its on a 1996 formula and we really need to get under the hood to get the belt on... so we can run it!! just did a cam (230/236 112) and it idles nice, just need to get this latest problem fixed... any help appreciated...
aLl i think of is taking out the head lights and trying to get to the latch somehow that way...difficult but....what else is there...? unless there's a way to reach if and rlease it from under the car...but I think the radiator equipment would be in the way.
well, today I am going to jack the car up and start taking brackets and hopefully enough stuff out of the car enough so that I can clear to the hatch... wish me luck... any other ideas?
the lights are already out of both sides, still no room to reach hatch.
If I remember correctly you should be able to pull out a few of the panels below the front fascia, then undo the pushpins running in front of the radiator, and be able to squeeze your hand in there.... I think.
Actually when my cable broke(among other things),I just used a coat hanger,bent the end ,crawled under the car,and with a flashlight,found the mechanism,pulled on it ,and it released.(I think I had to pull it to the left,or right,can't remember.Hope this helps.(Now,putting in a new cable,we are talking hours of fun.My02)(I don't remember removing any under car stuff though.)
alliance12364
09-17-2015 08:43 AM
