View Full Version : LT1 Based Engine Tech
- Building 396...what to do about valvetrain?
- ARIZONA SPEED & MARINE LT's fitment 95Z28
- Pushrod length for lt4
- New Clutch Installed. SES now flashes and Falls on Face...
- starting problem
- Best Scan Tool For beginner
- DEX-cool v.s. GREEN STUFF- EVERYONE
- Help with electrical or fuel troubles?
- ecm controlled hei distributor module
- lt1 cam??
- 98 T/A LS1 in 96 Z-28??? How hard?
- fuel pressure question
- How much horse power should i have
- Gasket Change On Driver Side Header
- Looking for spark plug wires suggestions
- Jet Hot or Hooker Longtubes ? ? ?
- Check out this cylinder wall...what do you think?
- Factory tach issues, need some input.
- Heat Range
- Machining spring bases
- Assembly lube or heavyweight oil?
- Lt1 383 stroker missing at 4000-5000 rpm, NEED A GENIUS!!!
- Supercharged LT1 Stroker - any suggestions?
- Kooks y-pipe install problems... pics and a video inside...
- Valvetrain help needed quick
- How to check if opti is bad?
- new ignition, still have a miss and coil is arcing. need help!!!
- LT1 parts in Chicago area??
- Which function increases idle with A/C on?
- Isn't there anything better?
- PO410 and P0420.
- Need Oil Pan Advice... Still Confused
- How are you guys mounting your 685 boxes in the glove box?
- Crankshaft Gear Puller Part Number!
- Problems just dont end!
- engine swap
- Temp problems after opti install...
- vaccum leak slowing me down?
- re torquing heads after replacing head gasket
- VERY dissapointing 1/4 times. What Gives?
- Just changed driver's side header gasket, now temp gauge not registering
- Anybody running Dynatech Longtubes?
- i have some question's ?
- Why would headers cause false knock?
- Extreme GM guide plate and valve wear update...
- opti harness what fails?
- oil pressure drops to zero when car is hot and braking
- Do edelbrock throttle bodys whistle?
- ARP Hardend oil pump drive
- Let's play name this part
- People with single plane intakes inside
- Stock 24# injector spec's
- newby
- BOOKS on LT1 rebuilds????
- So basically, I hate my life.
- Delteq Ignition...Does yours work?
- lt4 hotcam
- 96camaro w/lt1 bogging but no ses codes
- Car Died
- 52, 58, or monoblade?
- opti placement
- anyone have an old cap and rotor I can have to run a test? In Colorado would be nice
- Anyone with LE1 package....Please respond
- LT-1 block
- Passenger Side Runs Bad
- lt4 hotcam kit
- Electrical problem FIXED
- Cannot figure this out!!! Help! lol.
- 4.3 lt1 crank?
- 383/355 question
- Gm847
- LT4 ED Timing set
- Beaten
- LE3 cam need a bronze gear?
- Cam Kit?..
- 3rd times not the charm
- finally installed my headers
- Lost Waterpump Sleeve
- LT4 Valve Covers Interchangeable Side to Side??
- le3?
- Can anyone confirm that I wired up my Mallory 685 right?
- Ai Trickflow heads
- could i fire it ???
- electrical problem??
- Borla at 150,000 think the 1,000,000 warranty covers
- Stumble, Hesitation, RPM's Jumping. Need to get this ironed out.
- Automatic Transmission Question
- why cant they make modding easier???
- Question for Head porters
- Looking to achieve 400 rwhp
- [edit] 4 sale
- 383 LT1 with (224/236 XE Cams) ENTER PLEASE!!!
- Heads for Stock elimnator motor
- Ahh!! Urgent Thermostat Help!
- Trouble starting car after it has been running
- New plugs, wires, cat delete, and now a miss...96 Impala
- Where do you put catch cans on LT1's
- What could this white smoke be.
- Pushrods - LE2 guys
- Making my own Taylor spark plug wires, quick question
- Electric Exhaust Cutout
- SES Code 26, replaced PCV Valve....
- Well, I drove my car down the street finally.
- LS1 injectors in an LT1
- Need advice on header set up
- Parts list for fixing a blown headgasket?
- 1.6 Rollers?
- Still P0100 CODE!! ahhhhhh
- Car is running horrible 1993 Z28
- Magnaflow cats are a real restriction
- 94 eng./comp. in a 97
- water pump gaskets
- need little help quickly..
- Diagnostic Help!
- no start
- no start
- no start
- Will exhaust leaks in my y pipe cause the car to lose power?
- Dyno tune in southeast Texas area?
- Which Spark Plug?
- Cam/Head/Lontube Package install question
- Head experts inside, how do these ports look?
- PCM for Less vs HPP, power diff ?
- Fan switch and Resistors
- anyone have tsp exhaust
- running super rich => gas in oil?
- Would these mods be worth it?
- 93 Z leaking oil out of front cover
- Need Help, car wont start
- Anybody get this?
- LT4 Hot Cam Kit vs. 1.6 Roller Rockers
- egr
- Help 1996 Z-28 WON'T START
- Timing chain cover gasket
- What do yall think
- Please Help, Temp Gauge Too High And Fan Stays On
- OEM Lifters for LE2 and Trickflow Heads?
- dyno results for pacesetter and boltons
- Where can i find all thread ?
- Overheating, but the thermostat is fine...
- More progress, pics inside(Interior)
- Does anyone have this??
- LT4 knock module vs. desensitizing knock sensor
- Valvetrain problems... .577 lift on 918 springs.
- opti at a parts store...
- trap speeds ?
- Felpro Oil pan gasket
- 95 lti bogging on hard excellaration
- Can't figure out oil leak..any opinions?
- I've got popping at the top of gears
- lt1 starter to block bolt size????
- i got ia sticking lifter i think ?
- A.I.R valve question
- cap/rotor or opti?
- Okay, I am ready to buy my car monday and need some pricing advice
- I May buy an LT1 car this week! Need advise/help!!
- Need some easy or free mods!
- GMHTP 396 Article
- P0410 secondary air injection
- What would cause engine to over heat?
- What do you think is harder on a stock bottom LT1, H/C or 100 Shot
- P0100 - Please Help
- P0336
- Finally got it dyno tuned on BRE cam setup!
- Intake manifold bolt holes (go into the engine?)
- Dyno results after mods!!!
- Someone please help me with this lifter problem!!!
- Rad on my LT-1 cracked!!!!
- need AC diagram
- SES light on after O2 simulators installed....
- IATs all the same?
- problems after removing front bumper support
- Car rumbles and almost starts, but doesnt.
- Spring recommendations for 503 cam
- How to align Hypertech 160 Thermo?
- opti install help
- 1995 383 LT1 stroker, UPDATE, losing all hope, in need of a genius
- Anyone have LE budget LE1 heads?
- Accel Opti, those that have it!
- HELP! I can't find my drivers side O2 sensor on my 97
- What would you charge another person to fix their car?
- T/B...Bigger or Not?
- 12's possible?
- LE2 Heads LE4 Cam ET's
- high rpm miss/stumble
- need some fast help. lt1/m6 swap into Iroc.
- Help on Loudmouth Install
- Ram powergrip or powergrip HD...oppinions please
- Whats the most HP you can get out of a stock LT1 cam?
- makin this short
- she lives again...kinda
- dexcool shooting out! HELP!
- Super Vic 383 LE2 down on power
- ...........Want to buy Daynomax muffle......NEED HELP...
- Rev limiter will not read over 1,000 RPM
- Got to see Edelbrock LT1 intake in person and pics
- how many people would be interested in sending me thier old crapped out opti's??
- water in opti
- Exhaust manifold help?
- clearance issues
- muffler advice
- can injectors be pressurized with fuel rail off manifold?
- Help me build a smog legal 383
- What Headers and Y-pipe For a 93 Z
- Am i the only person with this problem?
- Fast Break-in and Oil Analysis Results
- Failed Opti
- Question for all those 396 LT1 or LT4 guys
- What do autos dyno stock??
- New Here w/?
- removing lt1 oil pan, hard?
- No more TA for me...thanks for all the help over the years!
- another header thread
- head bolts for Iron Vs Aluminum heads
- Lt4 hotcam kit questions
- opti plugs wires help fast
- Codes i pulled off the car
- Just bought a 95 vert
- so... i got this hole in my head...
- chevy stock injectors vs Ford SVO .....
- HOW MUCH CFM DOES 95Z28 elec. fan pull.?
- Supercharger
- should i rebuild???
- MSD Failure Analysis - Pictures
- Replacing rear main seal
- VATS/Starting problem
- Disappointing LE2 Dyno #s
- Cant get thermostat housing off - sealant?
- Been away for 3 years and need new advice for my news camaro
- throttle adjustmen
- Crank the car over and antifreeze shoots out of radiator
- Can a valve cover breather cause running rich or high idle?
- fan problems
- brand new map sensor
- Mid RPM Miss/Bog Down
- Heat Shielding engine bay
- deltec?
- Oil problems
- buying a high mileage z28?
- lt1 swap but not what you think
- I've had a Comp R fail.
- I need a favor of someone
- What size pushrods?
- overheating issue
- Ignition blues
- Almost broke some grounds
- Granatelli Motorsports 255lph fuel pump?
- True Duals Finally!!! (w/clip)
- New guy with a question
- Changed plugs and wires, but have a question
