Gasket Change On Driver Side Header
Old Aug 10, 2006 | 11:05 AM
Fujimo's Avatar
I removed all the bolts, slid the old gasket out. I lined up the bolt closest to the front of the car then tryed to lined up the one on the back of the car and thought i had it. I slid the gasket in and started adding bolts, tightening middle then outwards, but when i got to the end the bolts closest to the firewall wouldnt turn without lots of strength so i thought i possibly might crossthread them so i took all the bolts out to start again.
Is this the right procedure? Am i missing something, i cant seem to get the end bolts lined up so they will screw in nicely. Should i remove the steering column shaft thingy thats held on by two 11mm bolts?
thanks for the help
Old Aug 10, 2006 | 01:32 PM
Schweet97Z's Avatar
Re: Gasket Change On Driver Side Header
i would run a tap in the bolt hole to try and clean it up. then try again.
Old Aug 10, 2006 | 04:44 PM
BUBBA's Avatar
once you get the threads straightened out---on the holes where the bolts don't turn easily, just start the bolts in all the holes. Don't tighten any of them until they are all well theaded in. I assume you are using 1" bolts.
Old Aug 10, 2006 | 05:03 PM
Rising Phoenix's Avatar
The same exact thing happened to us when we changed the driver's side gasket yesterday. I was also worried it was cross threading or something.
We had to clean up the bolt with a thread cutter (it worked really well) then stuck an narrow air compressor extension into that hole and blew it out a bit. After that it went right in without any problems and we were done.
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
