opti placement
Old Aug 9, 2006 | 11:12 AM
95z28man's Avatar
opti placement
I just got my new opti today and before I install it I want to make sure I get it right the first time. I'm assuming the dowel pin is supposed to go into the hole on the opti that has the little notch out of it? If thats correct, how can I make sure it's in there right? It's kinda hard to see when your putting it on.
Old Aug 9, 2006 | 01:32 PM
Re: opti placement
http://shbox.com/1/opti_back.jpg
I would mark the location of the rotor on the old Opti, before you take it off. Put the new Opti on with the rotor in the same position. The "margin" for error is 120deg. You should be able to hit it right by orientating the rotor the same way on the old and new units.
Old Aug 9, 2006 | 02:46 PM
MPB70350's Avatar
Re: opti placement
If i remember correctly it only goes in one way
Old Aug 9, 2006 | 03:24 PM
95z28man's Avatar
Re: opti placement
Well the old opti is already out and I think I may have bumped it from it's original spot, so I guess I'll just kinda eyeball it and try to put it in the correct spot. If the margin for error is 120 then it shouldn't be much of problem.
Old Aug 9, 2006 | 04:04 PM
Re: opti placement
It can go on several ways (as many have proven). It only goes on correctly one way.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
