I need a favor of someone
could someone with a 93 lt1 car take a pic of the engine bay for me,I need a pic of where the IAT comes from,I know it comes from the TPS but I dont know which wire it is,and what it looks like,id appreciate it if someone could help me out
Re: I need a favor of someone
The TPS is on the wiring bundle that is routed in between the alternator accessory bracket and the throttle body. You should see wires spitting off out of the loom going to the TPS located on the passenger side of the TB, the IAC which is located on the bottom of the TB, and the IAT which would normally be plugged into the intake elbow. Given that you're isn't present (going off memory from the other board) I would look for the wires to be tucked behind the alternator or hanging down alongside the waterpump/opti.
Originally Posted by RE AND CHERYL
If your refering to the intake air temp sensor is in the elbow before the TB. Can't miss it. It's the only sensor there.
Re'
Re'
A picture won't help you a lot because its pretty crowded in that area.
The wires going into the IAT are black and tan (or maybe gray, its hard to tell)
They go through some split tubing under a coolant hose and then into a larger section of split tubing along with the wires from the sensor in the passenger side of the throttle body.
NewsBot
Dec 3, 2014 12:30 PM
