HOW MUCH CFM DOES 95Z28 elec. fan pull.?
Old Aug 3, 2006 | 05:56 PM
dutss707's Avatar
Smile HOW MUCH CFM DOES 95Z28 elec. fan pull.?
Like to upgrade my Cooling system with a BeCool Rad, and an
improvement in the "Fan" area.
I would like to know how much cfm the stock electric dble fans
pull....I heard somewhere around 1500 but am not sure.
95Z28LT1A4: Red w/Black Ttop: racetronics fuel system, full race
suspension: 3:83 RP: Holley 58mm, etc....too much to list.
Old Aug 3, 2006 | 06:39 PM
96capricemgr's Avatar
Re: HOW MUCH CFM DOES 95Z28 elec. fan pull.?
Fans only do the cooling at low speeds. If the engine is making power due to throttle opening low speeds will only be for a couple seconds then forward motion takes over as the air supply for the radiator. With a good radiator they can cool A LOT, good luck getting your info but at the same time I think it would be a waste of money to try to "upgrade" them.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Kawi
Sep 28, 2015 09:01 AM
SEOJustin
Sep 24, 2015 04:39 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
