dexcool shooting out! HELP!
Old Aug 4, 2006 | 09:32 PM
baddboy1705's Avatar
Exclamation dexcool shooting out! HELP!
i have a 96 Z LT1 and took it out for the 1st time in 3 weeks....drove 31 miles. on the way home (freeway) i noticed a burning smell...pulled over opened the hood and light smoke came rolling out...couldnt see anything so i made it home and got my shop light out... then all the sudden coolent started flowing out of my reservoir.....WTF is going on? car wasnt running hot, plus i had my slp fan switch on high...(and the fan motor is fine) ?!?!?!?!? thanks
Old Aug 4, 2006 | 09:47 PM
StephenDeli22's Avatar
Re: dexcool shooting out! HELP!
Sounds like a hose bursting
Old Aug 4, 2006 | 09:48 PM
you mean about to....or already did? the only leaks were from the cap of my res.
Old Aug 4, 2006 | 09:51 PM
Oh im sorry I missed that part about it coming out of the resovoir.
Old Aug 4, 2006 | 09:52 PM
its cool.....any other help?
Old Aug 5, 2006 | 12:30 AM
95LT1conv's Avatar
thermostat or head gasket.
Old Aug 5, 2006 | 12:47 AM
HardcoreRM125's Avatar
What he said ^ ...
With it cold, top off the radiator. Let the cap off. Start it and have someone watch the radiator. If water surges up out ( Or gushes like a gieser ) your looking at a head gasket for sure. If not, I would replace the thermo, and go from there ...
Old Aug 5, 2006 | 01:07 AM
Originally Posted by HardcoreRM125
What he said ^ ...
brand new thermo....and the rad seems to be ok... i just dont know why it would overflow from my res like that....have you guys ever heard of such a thing?
Old Aug 5, 2006 | 02:19 AM
Heritage's Avatar
Isnt it supposed to come out if the cap is off?? Isnt that the point of having a pressurized cap? Or are you saying if it gushes out right when the car starts up, theres a problem? I dont know a lot, but it seems that once the car runs for a matter of time it will be coming out, one way or the other. How long should it take? Dont really understand this so if someone could clear it up I'd appreciate it
Old Aug 5, 2006 | 06:44 AM
anaik's Avatar
Try a new radiator cap. It sounds like it isn't holding pressure when the coolant gets up to temp and expands, and is allowing it to fill and overflow your reservoir.
Old Aug 5, 2006 | 08:54 AM
When you have all that pressure from the cylinders leaking into your coolant system it needs some place to go...
Old Aug 5, 2006 | 08:57 AM
moparman's Avatar
You need to pressure test the radiator. You can get the "loaner" tester at Autozone, but they want a deposit that you will get back when you return the tester.
Old Aug 5, 2006 | 12:59 PM
ok.... im going to tey this one more time....
its coming from HERE
not here
Old Aug 5, 2006 | 01:02 PM
Dave89IROC's Avatar
not here
yes, that is why he said get a new rad cap, but you want to make sure you don't have a blown head gasket
Old Sep 2, 2006 | 12:55 PM
Mushijobah's Avatar
Did you ever figure this out, my car did the same thing!!
Devinfoote87
Feb 12, 2016 03:21 PM
karpetcm
Sep 15, 2015 11:07 AM
Pwilson59
Sep 3, 2015 08:47 PM
jeff94z28
Sep 23, 2002 09:52 PM
coolrunner
Jun 19, 2002 11:54 AM
