Almost broke some grounds
Old Aug 2, 2006 | 09:02 PM
hey01's Avatar
When i was pulling my coil off i was taking off the stud with the bolt...well those wires that connect on with the ring connector started twisting and it tore the ring connecter almost in 1/2
its stll about 2/3's whole but im having a hell of a time finding some ring connectors that BIG.
the car has been running fine for months butttttttt that isn't something i wanna leave like that regardless.
what are all of those ground wires and could i ground them somewhere else?
Old Aug 2, 2006 | 09:16 PM
Re: Almost broke some grounds
You shouldn't have any trouble finding ring terminals of that size. I would leave the grounds where they are. They won't really reach anywhere else due to the length of the harness.
Old Aug 2, 2006 | 11:17 PM
SnakeOiler's Avatar
Yep, I did that. Snapped all three wires. I put on new ring terminals 12AWG - the ones with the yellow color insulator.
Old Aug 3, 2006 | 07:49 AM
hey01's Avatar
will the insulator stuff melt from under hood temps?
Old Aug 3, 2006 | 08:09 AM
GetaZforgetGT's Avatar
I've replaced those ring terminals quite a few times now.
Seems like they galled to the nut and you don't really have much of an option once you start removing the nut.
Old Aug 3, 2006 | 08:11 AM
hey01's Avatar
where did everyone find their ring termnials, I hit lowes and some hardware stores but i haven't found a ring connector with a RING big enough to go over the bolt stud.
Old Aug 3, 2006 | 08:22 AM
I happened to have them laying around in the shop but I would think you could pick them up at any autoparts store.
I just went to Advanced Auto's website and they show a ton of different gauges and styles...may want to check them out.
Old Aug 3, 2006 | 08:24 AM
hey01's Avatar
thanks i'll be hitting them on the way home from work
truecontr3
Oct 11, 2015 09:30 AM
autoxr166
Sep 25, 2015 04:21 PM
DelSoto
Sep 19, 2015 05:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
