egr
Old Aug 7, 2006 | 11:48 AM
gillt1's Avatar
Question egr
Hi guys,if I've had egr system deleted , do I have to remove egr valve and block off port to intake,the reason I'm asking I have a severe stumble and stalling at highway speeds ,opti replaced ,any suggestions Thanks
Old Aug 7, 2006 | 03:54 PM
SantaCruz163's Avatar
Re: egr
Check your fuel pressure.
Old Aug 7, 2006 | 04:22 PM
Re: egr
The EGR will affect your engine's performance only if it is leaking. Blocking off the riser tube from the #8 primary to the back of the manifold will insure no exhaust gas can leak into the intake manifold. In the remote case that the EGR pintle seal is leaking air into the manifold, removing the EGR valve and blocking off the hole in the manifold would eliminate that possibility.
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
