People with single plane intakes inside
Old Aug 9, 2006 | 04:29 PM
Schurters LT1's Avatar
I am looking for all the info i can get on this, and YES i have read just about every post out there
How has got this to fit under the stock HOOD !!!!
what about the IAC
what about the throttle cable and cruse
fuel lines, feed return, FPR
any any INFO would be great thanks
Jeremy
Old Aug 9, 2006 | 06:54 PM
fast 93 z's Avatar
Re: People with single plane intakes inside
what about the IAC
Jeremy
Will not fit under stock hood. If you go with an elbow from www.intakeelbows.com you can keep your 58 mm throttle body and stock IAC, TPS, throttle cable.....etc. Fuel system you will have to build yourself with the fuel line adapters and aeroquip fittings, braided lines....etc. You can get a good Aeromotive FPR that will have a return.
more pics here: www.fast93z.com
I went the hard way. With the PTE elbow and 90mm t-body.
Tony Shepherd
Old Aug 9, 2006 | 11:34 PM
thanks for the help TS, there has to be people out there that have mad this fit ??? anyone have pics ????
thanks
Old Aug 10, 2006 | 06:48 AM
TQdrivenws6's Avatar
Mine fit under the stock WS6 hood after some carving. There is a support brace that runs down the middle of the hood that needed to be removed to clear the elbow/throttle body.
I went with the Wilson 90mm throttle body so that requires a few things...
The IAC, you can get an adaptor from:
http://www.raceprovenmotors.com/cart...a&filter_id=10
You will see the TPS adaptor there also.
I just rewired the TPS into the factory harness.
Get a IAC for a 93 camaro Z28 and the corresponding pig tail to wire into your harness.
For the throttle cables, I got a monoblade throttle cam from AS&M, it was about $25 I believe. Then I modified the stock LT1 throttle cable bracket to mount to the intake elbow to manifold bolts. This allowed me to reuse the stock cables. I mounted the throttle cam onto the Wilson t/b by just drilling one hole in the cam to mate up with one of the pretapped holes on the throttle body, then I got it lined up and drilled and tapped for another bolt.
As far as Fuel, I converted to -6AN from the hard lines forward. I ran a single feed along the stock routing up to the opening under the hood. Then it enters a y-block that I made here at work (machine shop). But I pretty much copied the design of the Aeromotive unit that you can get at any speed shop. Then the two feed lines enter the front of the Edelbrock 3630 rails via -6AN lines. The returns are also -6AN coming out of the back of the rails into an Aeromotive 13109 afpr which has two inlets and one outlet to the tank. The return then follows the stock routing back down to the factory hard line.
Old Aug 10, 2006 | 08:50 AM
WOW thanks for the info guys Big help.
There has be someone that got this to fit under a stock hood.....Anyone ???
Old Aug 10, 2006 | 08:52 AM
TQdrivenws6,
do you have any pics of your car with this set up ???
Old Aug 10, 2006 | 08:54 AM
Stock hood will NOT clear a Super Vic, and good luck with any other single plane. I needed ~2.25" above the plastic cowl piece to clear the elbow. My elbow flange is milled as thin as it can get with the vacuum ports in it, still only 1/2" thick. I don't see where you are going to find a single plane worth your time that will be 2" shorter. The elbow can't get much tighter of a short side radius if you want to maintain flow, so you can't really save any height there either.
EDIT: Pics in a second.
Old Aug 10, 2006 | 08:57 AM
Here are the pics:
All of these pics are with the intake sitting in there without any gaskets which ads an easy 1/8-3/16" to the height also.
i was going to run the Vic E the hight on that is 4.58 " i think that puts it and the same hight as the stock LT1/4 intake then i need to fig out the room from there......
Old Aug 10, 2006 | 08:59 AM
WOW cool thanks,
Do you no the hight of the elbow ?
thanks
Jeremy
Old Aug 10, 2006 | 09:08 AM
I would say about 5.5" but that was scaling one of the above pictures. It should be in the ballpark though.
Old Aug 10, 2006 | 05:41 PM
just trying for more info ???? anyone
Old Aug 10, 2006 | 06:46 PM
engineermike's Avatar
The Victor EFI is almost identical in height to a stock LTx intake manifold. You can fit an elbow under the stock Z28 hood, but it will have to be custom fabricated.
Old Aug 10, 2006 | 06:48 PM
Turbo6's Avatar
I have nothing else to contribute on the subject but can confirm what the others have said. You probably won't fit it under a stock hood. I also have a WS.6 hood and a super vic and things are tight, tight. I'd either plan on a different hood or a different intake. HP=$$$
Old Aug 12, 2006 | 06:28 AM
I will be doing the Vic E , because of the hight, and the custom elbow to fit under the hood.....well i will have to look into that...
thanks
for the info guys...
