LT-1 block
Old Aug 9, 2006 | 08:05 AM
95TAMaddog's Avatar
LT-1 block
Is there a difference between an 1988 350 block and an LT-1 block. Can it be used for an Lt-1. Just wondering. Thanks in advance.
Hughey
Old Aug 9, 2006 | 08:24 AM
1BadBrd's Avatar
Re: LT-1 block
LT1's block have different coolant route. LT1's are reverse coolant.
Old Aug 9, 2006 | 10:07 AM
Re: LT-1 block
The entire front end of the LT1 block is different from the earlier Gen 1 SBC engines. Different water pump configuration, a "pocket" for the Optispark distributor, resulting different timing cover. If you put your Gen 1 block in an LT1, you have to either use the Gen 1 heads, or have the LT1 heads converted to the reverse flow cooling passages. Then you would have no way to feed your LT1 PCM without the Opti, or developing a system to provide the Opti high- and low-res signals to the PCM. The LT1 PCM can not function without the low-res pulse. You would require a distributor to be installed, or conversion to an aftermarket bank-to-bank ECU.
Some info and photos:
http://www.automotiverebuilder.com/ar/ar99928.htm
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
heus
Sep 8, 2015 12:01 PM
