Cam Kit?..
Old Aug 8, 2006 | 09:42 PM
Lt1son's Avatar
Cam Kit?..
Well i have a 94z With 4'11's Lt's and normal bolt ons..Got a nice lifter tap now...so i was thinking a cam and lifter kit..Along with rockers pushrods..and springs..just wondering is sum1 makes a kit that has all that stuff in it..at a reasonable price..or is mix matching my best bet..im at like 13.3 now (1/4mi)..ould like to get in high 12's...ne help w. part #'s would b great..(yes i searched found some not all..) thanks
Old Aug 8, 2006 | 09:47 PM
96capricemgr's Avatar
Re: Cam Kit?..
Bet you it is an exhaust leak not a lifter. 99% of the time I have heard someone blame a lifter it has been a leak at the manifold.
You are not going top find a "kit" especially since with these roller cams it is perfectly acceptible to reuse lifters with a new cam. That said I am sure many vendors could help you pickout the right parts.
I know www.advancedinduction.com offers valvetrain packages you would just call and talk to them about what you want, they can help you pick a cam and matching springs and get the valvetrain package with it.
Old Aug 8, 2006 | 09:50 PM
Lt1son's Avatar
Re: Cam Kit?..
Thanks..I thought a exhaust leak 2..replaced both gaskets..doubled both up with copper...the noise comes and goes...if i dont drive it hard,,its not there...when i get on it it comes back..i put bg MOA in it and it went away..if i change the oil w/o adding it..it comes back as soon as i get in it...did the old screw driver trick and it sounded like it was comin from the Ds..the gasket that i had blow was on the PAss..side..thanks for your help
Dmonty
Jun 2, 2015 11:19 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 21, 2002 03:55 AM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
