LS1 injectors in an LT1
Old Aug 8, 2006 | 04:11 AM
AF96Z28's Avatar
I am looking at getting a set of Z06 28 lb injectors to replace the 100k mile stockers. What would be some problems I might run into usinf the 60ish psi ls1 injecctors vs. the 43 psi LT1 injectors?
Old Aug 8, 2006 | 04:23 AM
RE AND CHERYL's Avatar
Re: LS1 injectors in an LT1
The injectors are basically the same flow wise once you take the pressure difference into account. Consittering the cost of having your PCM reprogramed for 28lb injectors (if you raise the fuel pressure), I would just buy a set of stock replacements. I'm also not sure if there woiuld be any problems with using the LS1 injectors at the lower 43psi the LT1 uses.
Old Aug 8, 2006 | 09:35 AM
TransAm396's Avatar
lol...same boat I was in 2 years ago..just get SVO30s
Old Aug 8, 2006 | 10:07 AM
Gripenfelter's Avatar
Aren't the LS1 injectors longer? Can you bolt down the fuel rail properly?
Old Aug 8, 2006 | 10:44 AM
Z28SORR's Avatar
Get the "cough", Ford injectors. They're cheaper and compatible.
Old Aug 8, 2006 | 01:09 PM
AF96Z28's Avatar
Thanks for the replies. I can pick up these injectors for $50. Also I use tunercat and can make necessary adjustments. It is a good point about length etc. Looks like I'll be looking at some SVO's
Old Aug 8, 2006 | 05:40 PM
96capricemgr's Avatar
I am using some injectors that were 32lbs on a LS1 which is roughly 28lbs at LT1 43.5 pressure, they were a little shorter actually. There were also maxed out with my heads cam setup. I would agree with the others just consider some SVOs though I would say consider the 36lbs, 30s would get the job done but the 36 will leave more room for growth.
rideordie
Nov 5, 2019 04:52 PM
Sergio
Jan 27, 2016 04:27 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
Jul 4, 2005 05:00 PM
