makin this short
Old Aug 4, 2006 | 10:55 PM
Daniel6718's Avatar
makin this short
this might belong in advanced tech....
my understanding lt1 is balanced by flywheel and crank pulley/dampener whatever its called
so i have a stock motor with a zero balanced flywheel and a vibration....what my fix????????
stock flywheel from junkyard or oreilley? or tear the motor down and redo this...?
Old Aug 4, 2006 | 11:20 PM
breakmyfootoff's Avatar
Re: makin this short
The damper has nothing to do with the balance on a stock LT1. They are balanced by thr flexplate/flywheel on the rear. If you have a nuetral flywheel/flexplate on a stock rotating assembly that will cause your vibration. Any stock one will fix it for you, they're all the same as long as it's from an LT1.
Old Aug 5, 2006 | 01:44 AM
Daniel6718's Avatar
is there a way to have mine modified since i just had it surfaced ect and i dont wanna pay 130 for a new one...
Old Aug 5, 2006 | 10:28 AM
I've yet to hear of someone adding wieght to one of the nuetrally balanced flywheels, but I'm sure it can be done. Just take it to a machine shop and ask them. It doesn't have to be balanced with the rotating assembly since they are all the same.
Old Aug 5, 2006 | 07:45 PM
Daniel6718's Avatar
stuff stinks...it was the flywheel...but i got a new gm piece for 145...so its ok...put it on and its smoothe as glass..then trannys on its way in now...
heres a pic of the 2
new piece on the left
Old Aug 6, 2006 | 12:07 PM
Sorry ya had to spend another 145 bucks, but at least your car is fixed now
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 11:56 PM
68camaroboltz
Oct 5, 2015 01:46 PM
football4life
Oct 4, 2015 07:48 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
