new ignition, still have a miss and coil is arcing. need help!!!
Old Aug 10, 2006 | 12:19 AM
street demon2k3's Avatar
alright i have been trying to track down a miss that my car has had since i put the new 355 in. first of all i have replaced opti 2x, coil 3x, plugs 3x, wires 2x, 02's 3x, new icm off my bros Z28, and just bought a new knock sensor as well. now last saturday i bought new MSD wires/coil, and some NGK TR55 gapped @ .50 and the car ran like a raped ape. next day on sunday i took the car to work and the car started to miss a little and i could tell the ecm was pulling the timing cuz i had a DTC43 (knock sensor) when i got to work. i noticed that the coil was arcing real bad when i got home and i just changed it out today with another MSD coil and it runs better it still breaks the tires loose at 50mph (crappy tires) but i have a DTC 33, 55, 64.
what im thinking is that maybe the plugs are too hot for my compression. my heads are shaved, running impala gasket, -5cc flat tops. somone told me that i should go with a colder spark plug like a tr6 or something like that. what do you guys think?
Old Aug 10, 2006 | 03:12 PM
Re: new ignition, still have a miss and coil is arcing. need help!!!
anyone have a clue why my coil is arcing or why i stil have the miss???
Old Aug 10, 2006 | 06:30 PM
93yellowta's Avatar
Well just a thought, I put on a new accel 300+ ign. system, and new accel coil, no problems, so then I had heads and cam put in, when I got it back I had the same prob. and the coil was arching on both sides of the coil... what happened was the h/c installer took off the ground cable, and mounted it on the block, so I put on another ground cable from frame to coil and that fixed my problem, sorry for long post... but you can try that..
Old Aug 11, 2006 | 08:44 AM
i'll check the grounds to the coil but i know that they are all on there. only thing is that some of the wires are cracked and exposed, but again they are ground wires so i dont think it matters.
Z28Freak86
Apr 30, 2024 05:37 PM
captcorvette
Mar 7, 2015 12:37 PM
Ari G
Dec 11, 2014 03:21 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
